Question about Samsung DV448AEE Electric Dryer
DRYER WON'T SHUT OFF
I'M WORKING ON A SAMSUNG DRYER, MOD. # DV448AEP/XAA, SERIAL # W03L54BQ801335X. THE PROBLEM IS THAT IT WON'T SHUT OFF. WHETHER ITS ON "AUTOMATIC" OR "TIMED" DRY, THE CLOCK COUNTS DOWN TO 1 MINUTE THEN THE DRYER CONTINUES TO RUN INDEFINITELY. WHEN I OPEN THE DOOR I GET THE FOLLOWING MESSAGE, "DOOR IS OPEN. CLOSE DOOR THEN RESTART. "IF PROBLEM CONTINUES CALL SERVICE. SOLUTION 1/2". WHEN I CLOSE THE DOOR THE MESSAGE I GET IS, "CYCLE COMPLETE". I CALLED SAMSUNG TECH. SUPPORT AND I WAS TOLD TO REPLACE THE MAIN CONTROL BOARD. I REPLACED THE BOARD AND IT WORKED PROPERLY FOR 2 LOADS THEN WENT BACK TO THE ORIGINAL PROBLEM OF GETTING DOWN TO 1 MINUTE THEN CONTINUING TO RUN INDEFINITELY. I THEN REPLACED THE THERMISTOR. I PUT IT BACK TOGETHER AND IT WORKED FOR 2 LOADS AND NOW IT'S BACK TO RUNNING CONTINUOUSLY. I CALLED TECH SUPPORT AGAIN AND THEY SAY THAT THE ONLY THING IT CAN BE IS THE MAIN BOARD. BEFORE I TRY ANOTHER BOARD I THOUGHT I'D SEE IF ONE OF YOU GUYS WHO ACTUALLY WORK ON THESE MACHINES HAS ANY IDEA ON HOW TO REPAIR THIS DRYER BECAUSE SAMSUNG'S TECH PEOPLE DON'T HAVE A CLUE OTHER THAN TO SAY ITS A 4 YEAR OLD MACHINE AND THEY HAVE NEVER HEARD OF MY PROBLEM BEFORE.
2 Suggested Answers
  • 4736 Answers
SOURCE: Samsung over the stove microwave, SMH8165B, 1 1/2
Unless, something has been mishandled the last 1 1/2 months you've had and been using the microwave, It sounds like a manufacturing defect. In which case, since it's only 1 1/2 months old, it's covered under warranty for repair or replacement by Samsung. Consult your Owners Manual about how to contact them concerning this. Keep in mind, you must still have your proof of purchase for the Warranty to be enforceable. If you don;t still have the sales receipt, your credit card statement showing the purchase may suffice.
Hope this helps you out.
Posted on Feb 17, 2011
Samsung dryer won' shut off dv520aep/xaa
If it's in the timed cycle, the timer motor is probably bad, preventing the timer from advancing through the cycle.
If it's in the auto dry cycle, the moisture sensor could be bad, so the dryer thinks the load is still wet.
Mar 07, 2017 | Samsung Dryers
WHY DOES MY SAMSUNG MODEL DV448AEP/XAA SENSOR DRY MODE RUN FOR TWO MINUTES AND THEN WILL GO TO COOL DOWN MODE, ALL OTHER DRY CYCLES MANUEL AND STEAM CYCLE OPERATE FINE!
Sensor is screwed or the timer relay for that part of it is not working . Go to an appliance store to get wiring diagrams ordered and might even know about the problem w that model
Feb 19, 2015 | Samsung Dryers
Samsung dryer dv448aep/xaa drum not spinning. What do I need to do?
please checkthat the belt is not loose /worn /broke .
Aug 24, 2013 | Samsung Dryers
Samsung dryer hums but the drum does not turn
It sounds to me like the drive belt that goes around your dryer tub has broken.
images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Oct 27, 2012 | Samsung DV448AEP 7.4 Cu. Ft. Electric...
My Samsung dryer Model #DV448AEP/XAA has stopped heating. It runs but does not heat. The lint trap is cleaned out with every load and we have taken the exhaust hose off and cleaned the dryer and the...
I think your heating element is burned out. You can find parts at repairclinic.com
If you remove the element (unplug it first of course) you will be able to tell if it is burned out by looking at the actual heating coils. If there are any breaks in the wire anywhere you know its the problem.
Good luck
Dec 12, 2010 | Samsung Dryers
I have a Samsung Model # DV448AEP/XAA and it has stopped heating. We have cleaned the lint that we can see and taken the lint hose off and cleaned that out. The dryer is still not heating. Any assistance...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 12, 2010 | Dryers
How do I repair a broken element on my DV448AEP dryer until it can be replaced?
You can't do this. Sorry, once the element goes bad there's no temporary fix. Rich
Sep 26, 2010 | Samsung DV448AEE Electric Dryer
Samsung DV448AEE Electric Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
