Question about Fujitsu New Original ARRAH2U Remote Control
Trying to set the time on the remote - Fujitsu New Original ARRAH2U Remote Control
How do i set the time on a vcr that normally uses a wheel but i'm using an universal remote
  • most universal remotes usually only do the simple commands like power, play, fast forward, rewind, pause, stop.
  • It may not be capable of setting the time.
  • If the remote is able to be switched to just work for your VCR you could try to press the menu, input or setting buttons to bring up any type of menus that would possibly help. If that doesn't work you may not be able to set it with the remote.
Feb 15, 2015 | Universal Televison & Video
Tv is locked and wont turn on. i have no remote
Hello
If RCA tv has locked accedently and you haven't its original remote handset it is almost impossible to unlock it. Just try to get its original remote control from any of your friends or relatives who owns the same model of RCA set, borrow it from them for just unlock your set and try the following tricks. One amoung them will surely unlock your RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
May 15, 2011 | RCA 24F512T 24" TV
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Sinotec:
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
Feb 06, 2010 | Sony RMV210 Remote Control
How do you reset the clock
Turn on the lights in your room and it will be obvious. On the Bose Wave Music System clock radio remote there is a + and - button labeled "time." This is how you set the time. Hold either the + button to move the time forward or the - button to set the time backwards. You don't need to push any buttons before you press the + or -. After you have set the time you can press the "alarm time" button to lock in your changed time.
The standard remote does not have a back-light feature. However, if you bought the optional larger remote and try to set the clock in the dark with the back-lit buttons, you won't be able to see the word "time" above the + and - buttons. This is because the word "time" is written on the metal part of the remote, which does not illuminate with the back-lighting feature.
Nov 01, 2009 | Bose Wave music system large Remote...
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
Trouble turning on the tv at times
The next time I try to turn the unit on the remote will not work or I can not turn the unit on with the switch on the side.
This statement leads me to believe the IR receiver and associated set-top button circuit may be at fault.
If you haven't hammered the set to pieces yet, try this; next time it fails to respond to the remote, put the remote in your freezer for 2-5 minutes (not longer, the batteries won't appreciate it) and then try it again.
If it then functions normally, then a certain integrated circuit (PT2222 or PT2221) may be from the same lot as mine and is abnormally sensitive to warmth. If this does make a difference, try removing the battery compartment cover and intentionally leave the remote face down.
If these tests don't seem to make any difference to the remote, then it is likely that the receiver end in the set is faulty.
Jan 27, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
I cant set my universal remote to my magnasonic tv
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
Dec 24, 2008 | RCA 257003 Remote Control
I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
Oct 14, 2008 | Logitech Harmony 880 LCD Remote Control
Fujitsu New Original ARRAH2U Remote Control Logo
56 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
