Question about Honda Garden
Repair drive axle
Right rear wheel bearing feel out and axel is rubbing frame seems to be missing a bushing need a parts diagram to be sure
    Master:
  • 969 Answers
Google model number parts.
Posted on Jul 04, 2015
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
  • 111 Answers
SOURCE: model 200013 drive axel moves to the right to far,
There are e clips that hold the transmission in place. They go in a specific order to make it work correctly. I have included a link that will show the correct placement for the e clips and spacer rings. I might mention that this is an hour long job when you know how to do it. So be ready for it to be time consuming. Alternately you can take it to a Toro repair shop. The second link is to a dealer finder, to show you where the closest dealer is to your. I hope this helps. http://www.partstree.com/parts/?lc=toro_consumer&mn=20013%2C+22%22+Recycler+Lawnmower%2C+2003+%28SN+230000001-230999999%29&dn=3350_221-369176-0006
http://www.toro.com/locator/index.html You will need to click on the link that says homeowner.
Posted on Apr 06, 2011
  • 6468 Answers
SOURCE: cub 2138 rear hubs are loose on the axle... any one make a repair kit for this concern.... the tractor has been a trooper 500 plus hours on the meter
is the key sheared?
Posted on May 09, 2012
  • 6468 Answers
SOURCE: What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Posted on Jul 16, 2012
  • 4 Answers
SOURCE: Wheel came off. Can I replace just axel instead of hydro transaxle?
The hydro Transmisson Is not the easyest to repair. That is probably way they said that. plus the labor whould have been $350 to $500. So most shop won't repair them.
Find A break down on line so you can see what your getting into.
Posted on Aug 04, 2012
I have a 2004 ford explorer all wheel drive what would make the front differential fluid leak out where the cv axel is connected but this only happens when the wheels are turned and moving backwards
if independent suspension, I would be suspecting a failing bearing/bush inside the oil seal allowing the axle to move away from the oil seal lip
I f solid front axle , I would be checking the wheel bearings for failure and pulling the axle out of alignment with the oil seal in the axle housing
Dec 11, 2015 | Ford Cars & Trucks
Grinding metal sound over 30 mph
I believe that your Subaru has a transmission issue. There are quite a few things that will make a grinding noise. Wheel bearings, worn out brakes, damaged brake rotors or drums, loose or damaged brake calipers, defective hardware kit (for the brake shoes), torque converter, flywheel, U-joints, and CV joints. The interesting part of your symptoms is that you can only hear the grinding between 30-60MPH. I think you need to continue testing and inspecting components, one by one. You have all ready narrowed your search down. You know that the Brakes, CV joints, and Bearings are fine. So now you need to focus on the drive train. Inspect as much as you can from the flywheel, to the transmission, the drive shaft and rear axel, and the output shaft and front drive axel. If you can not find it yourself it may be time to send it in for repair. Let me know if you have any questions or new information, good luck.
Mar 07, 2014 | Subaru Cars & Trucks
The rear axle on my fortress 2000 scooter moves about 1/4 inch to the left or right causing the left and right wheels to rub on a bolt on the inside of the tires. Is there a way to tighten the axle to...
there is a bearing inside pin roller this get no grease unless pulled apart and serviced so if this has not been done the bearing is most likely worn out take apart and find bearing number very small ### so wash in solvent to see it go to auto parts store and order new 1
Oct 21, 2013 | Pride Revo 4 Wheel Scooter
Sounds like my mobility scooters electric brake is dragging
hi, Okay now get the back wheels off the ground and power the scooter , it important that you have some help now take your hand and place it on the brake with care while it moving forward with the wheels off the ground now the scraping, feel around the gearbox and where the axle connects to the wheels, you should find it worse either near the centre of the gearbox (main worm-gear drive worn or needs some lubrication) or one of the wheels (bearing worn on the axle part of the gearbox),
Health & Safely Warning: Please please take care when doing this , it 's important to understand that you don't need the scooter flat out , you must sure the scooter is secure and you will need some assistance. Take care when moving your hand around..
Mar 10, 2013 | Health & Beauty
I have to change the "rear chain adjusters" on a 2001 Honda XR100r. The left side is obvious (take off he axel nut and replace). But the right side is set in place under the main axel bolt. So I...
It is the axle bolt and it goes right through the wheel hub.
You will need to support the bike, as when this axle comes out , so will the wheel.
remove the axle nut and tap the axle out with a brass hammer, if it is corroded you may also need a brass drift slightly smaller than the axle to drive the axle out.
May 01, 2011 | Honda XR 100 Motard Motorcycles
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
How to change the rear axel bearrings on ford f 1=150
have to pull the diff cover,remove the small bolt that holds the pin,remove the pin . With wheels off ,push the axle in remove c-clip ,slide axle out. You will need a slide hammer to remove the bearing.(or pull both sides and drive out with a long piece of rebar from the other end)
Be sure to check the axle surface where the bearing rides,if is damaged the parts stores sell a repair bearing that makes the rollers ride in a different spot on the axle.(called "axle savers")
Nov 06, 2010 | 2001 Ford F150 Styleside SuperCrew
Bad rear axle bearing and seal on a 2000 jeep grand
the bearing does not always have to be really bad for the seal to fail. Centrifugal force will throw axle grease outward where it gets on the rotor. That can make it feel like the rotor is out of round. If grease got on the brake pads I'd replace them and perhaps even the rotor. As far as the caliper being frozen, possible....check it out when you have it apart. You can have more than one shoe untied at the same time. Not always, but it can happen.
When replacing the seal make sure you put some grease on the lip before putting the axle back in. by doing that it won't fail from dry running before the diff lube reaches it.
May 15, 2010 | 2000 Jeep Grand Cherokee
When i put my car in drive the rear right wheel makes a scrubbin
i had the same problem and i ended up changing the rear wheel bearings and axels, look under the car near the rear wheel seals, if they are leaking the axels are going to be worn also and need replacing.
Jul 11, 2009 | 1995 Mercury Grand Marquis
My rear passenger tire started smoking what could the problem be?
Are you sure it's the tire? It could be the brakes (not releasing) which could result in 'smoke'. The only way it could be the tire would be if it was rubbing on something, or you were spinning or locking up the tires. Feel the center of the wheel when you see the smoke, if it's very hot, it's probably the brakes not releasing.
Jul 11, 2009 | 2006 Pontiac Grand Prix
Garden Logo
50 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
