Question about Brother Office Equipment & Supplies
What does check readability of transmitted pages mean when sending a fax out on a brother Fax machine
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: UX B700 Sharp Fax machine send fax issue
here is the manual
http://www.sharpusa.com/files/fax_man_UX_B700.pdf
good luck
Posted on Dec 18, 2007
  • 66 Answers
SOURCE: My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: I have a Brother MFC-7220
It is cheaper to use online fax service compared to the conventional fax machine. This way is more flexible as well because you can send and receive faxes anywhere as long as you are connected to the internet. I use Popfax.com fax email service, and it's reliable.
Posted on Aug 20, 2010
  • 2385 Answers
SOURCE: Our HP 3015 fax is not sending a readable fax at
it only happens when you have something on the scanner
Over time, specks of debris might collect on the scanner glass and white platen, which can
affect performance. Use the following procedure to clean the scanner glass and white platen.
1. Use the power switch to turn off the product, and then unplug the power cord from the electrical socket.
2. Tilt the device control panel forward.
3. Clean the glass strip and the white platen with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
hope it solve the problem, if so rate the solution
Posted on Nov 22, 2010
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
I have a Brother MFC-7220 fax machine. When I fax I get "check readability of transmitted pages" errors. The receiver of the fax is only getting partial pages of the fax. I have had local and...
Aug 20, 2010 | Brother Office Equipment & Supplies
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
What does COM-E mean when we try to send fax's and the transmissions has this written on it instead of OK.
It means "Communication Error".
The result might be twofold:
- the fax didn't reach it's destination because of communications error (any kind)
- the fax did reach it's destination, but part of it may be unreadable or distorted, or some pages of a multi-page fax did not go through.
In many cases, what the device perceives as an erroneous transmission, is perfectly readable by a human. Therefore it's good to call the recipient and ask if the fax is readable and if all the pages were received.
Nov 13, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
Mar 11, 2009 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800
Hit the "Reports" button. Then hit the "4" button which is the transmition report. It will then print the verification of the transmition.
Sep 05, 2008 | Brother IntelliFAX 2800 Laser Fax
Does not scan pages until it makes connection
yes, the solution is that you are direct sending the faxes instead of scanning into memory which will start and complete the scan of all the pages as it begins dialing and transmitting. there should be a key on the control panel for memory or memory transmission, select it and your done.
mikey
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
2,099 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
