Question about Music
I have a Casio cps 700 keyboard with three keys that no longer work - how can I fix them?
2 Suggested Answers
  • 794 Answers
SOURCE: I have a Casio CPS-50
Hi coninni16,
If you need MPU-401 driver you may download it from this site. All you have to do is to click on Download Microsoft MPU-401 Compatible Driver underneath.
Hope it helps.
Thank you for using FixYa.
Posted on May 19, 2011
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Today I received my new Privia px830 and three keys works as an interruptor: play notes at full intensity. Are sensors cracked?
The sensors are rubber, and don't usually crack. Most of the time they are dirty and can be cleaned with rubbing alcohol and Q-tips VERY carefully. Also be careful of the ribbon wires inside the keyboard. The keys should just snap in and out. I cleaned mine a little while ago, and now it works perfectly.
Jan 06, 2013 | Casio PX-830 BK Privia
Casio keyboard won't power on
If batteries or power adapter does not power up the keyboard...possibilities are...if it has a fuse inside or fusible link check it.replace if blown.Another possibility is power component has a short. maybe from constant movement of power plug into keyboard.sometimes just by inserting the plug and wiggling it can solve the issue..having this fixed by a technician can cost a lot of money.but,if your keyboard`s value is less than the cost of fixing it,might as well replace your instrument.
Feb 21, 2012 | Casio 76 Key Smartmedia Keyboard
The power adaptor will not work on my casio cps-80 s Thanks,
You need to use the standard Casio adapter for the unit.. What adpater are you using? Sometimes the connector within the keyboard gets broken.
May 02, 2011 | Casio Music
I own a Casio CPS-80s Digital Piano. It stopped playing due to something related to it's volume / amplification has stopped working. I can barely here the sound of the music, so i maintain hopes of...
You will need to contact the Casio parts department and they can provide you with an electronic schematic for your CPS-80 digital piano. This document is not available to view on the Casio website Casio Parts Department
1-800-223-2001
http://support.casio.com/manuallist.php?rgn=1&cid=008
Dec 23, 2010 | Music
My Casio CTK-496 Keyboard has three keys (2nd octave F sharp, G, and G sharp that don't play anymore. How do I fix this?
First make sure a keyboard "split" option is not set.
Probably you are going to have to clean the key contacts. They are likely conductive rubber "pills" that are pressed onto a circuit board that has interleaved fingers. Clean both the black pills and the circuit board using ONLY 99% isoprophyl alcohol and Q-Tips.
Feb 17, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
7 of the keys on the upper end of my privia px-100 don't work. All other keys work fine. Is there any way to fix this at home?
It may due to faulty circuit board of the keyboard. Check for warranty and ask the vendor to replace the keyboard.
Dec 15, 2009 | Casio LK30 Note Lighted Keyboard
I fixed the dead keys on my Casio WK-200 keyboard. Now some...
Most of these have VELOCITY sensing and that involves two contacts per note. If the velocity sense on those notes is somehow not working, broken wire or trace on the board or short that MIGHT cause your problem.
Aug 12, 2009 | Casio Music
Casio ctk 496 keyboard
Unplugging and taking batteries out for 15 minutes should reset it back to factory.
Sep 10, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
51 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
