Question about LG Washing Machines
Lg washing machine wd 10480 stuck at rinsing. drain pump running continuously and water level frequency 262
Lg washing machine wd 10480 stuck at rinsing (step 13). drain pump running continuously and water level frequency 262.
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: My washing machine gets stuck after rinse cycle
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Posted on Mar 05, 2011
The Water does not stay in the washing machine! Admiral 10.1kg
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more. Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Apr 21, 2014 | Frigidaire Washing Machines
WATER OVERFLOWES WILL INT DRAIN ALL WATER OUT
Mar 12, 2014 | Frigidaire Washing Machines
Code OE
Stephen 1787 --
You are getting this code because your washing machine has tried for more that 10 minutes to drain the water out of the machine. Most likely the cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
First make sure that you unplug your washing machine. To clean out the pump filter you must drain the washing machine water. Manually bail-out the water using a small bucket or basin. Then use a towel to sop up any remaining water. Remove the pump filter, clean out any debris, and rinse out the filter. Plug your washer back in and restart the washing machine. Ensure that your machine is properly leveled. Washers that are too far out of level may not drain properly. If you are still having problems, write back. -- SWT
Aug 22, 2010 | LG WM-2277HW Front Load Washer
Not enough water in wash and rinse cycle
When you press the "SPIN SPEED" button and "SOIL
LEVEL" button the water level frequency should be
above 246. If it be below that number find the small
tube going to the control and blow it out. Get rid of
the sediment in the air bell and reconnect tightly.
Pump out water and retry. See page 23
Mar 13, 2010 | LG WD-16115FD Front Load Washer
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
New LG 10480 - softener liquid remains in the
Appeared to be a constricted water input hose - pulled the machine out from under counter and re-routed input and drainage hoses. Seems to be ok now.
Aug 18, 2009 | LG Washing Machines
Water can't drain out properly
hi
i think all the fuzzy logic machines have an electric pump so it is maybe not running to pump the water out or i have had problems with the electronics that run the pump
cheers grantsreps
Sep 29, 2008 | LG Washing Machines
Jun 09, 2008 | LG WFT1071TP Top Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
