Power fuses y is my lg wd8016c tripping out my power
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Dec 16, 2016 | LG Washing Machines
My LG wired remote control has no display - just turned off - seems to have no power - circuit breaker has not tripped? Any advice????
sounds like blown fuse in low voltage control wires. Due to short in wireing usually a wire rubbing against somthing due to vibration. Coating starts coming off wire then touches metal. If fuse replaced and it runs it will most likely will happen again unless short is located.
Aug 29, 2012 | LG Heating & Cooling
My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Feb 09, 2012 | LG Washing Machines
Our window AC unit stopped suddenly. Completely dead. The outlet has power. It's a 220V unit. LG window AC LW2510ER Any advise what it could be? Does it shut down when it's 100F outside? Thanks...
No - the outside temperature will not shut the AC down.
You say the outlet has power? Does it have the needed 220 volts? Most of the time 220 volts is on one switch, (that operates both 110 volt legs of power at the same time). - but sometimes each leg is on a separate breaker and if "one leg" trips you will still have power at the outlet (110 volts) but you won't have the needed 220 volts. While this is not likely - it is possible - so I would want to test the outlet with a voltage tester and determine the voltage. You might try checking in your breaker box and seeing if another breaker (110volt) is tripped. The same thing applies if you are dealing with fuses instead of breakers - determine the voltage at the outlet - and if you don't have 220 and only have 110 then look for a blown fuse or as I said above - a breaker tripped.
If you do have 220 at the outlet and nothing is running - I would be looking for an inline fuse of some sort within in the unit. Many of the newer units have them and they are usually easy to spot and all you have to do is to unscrew the fuse holder and replace the blown fuse. Be sure to have the power off when handling fuses.
Note: Be aware that while breakers/fuses can trip and blow without a serious problem going on - they (blown fuses/tripped breakers) are usually a sign of something significantly wrong with the unit.
Good Luck!
Jul 03, 2011 | LG Heating & Cooling
LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
Aug 12, 2009 | LG M8003L Air Conditioner
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
2008 LG Dryer will not heat.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 11, 2008 | LG DLE5977 Stainless Steel Electric Dryer
No signal on tv
i have 32ins Samsung displaying no satellite signal what is solution?
Aug 15, 2008 | LG Televison & Video
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
