Question about Garden
Homelite hpw2201 manuel
Put oil in,turned on engine,oil leaking out all over floor.what type of oil should I use in it and how much do I put in
Why does oil leak onto floor after oil and filter change from fram to valvoline type? 1995 camry 6cyl 3.0
my guess would be the seal from the old filter was still on the engine when you put the new one on it. take it off and check. is the seal on the old filter??
Apr 18, 2018 | Cars & Trucks
Previous homeowner left a homelite b250 0 801 backpack BLOWER. What type of fuel does it use note no owners manual on homelite site
It uses Hi test gasoline. NOT regular. You'll be having hard start problems if you use regular grade fuel. The engine is a 2 stroke which means you MUST mix oil into the gasoline before you put it in the blower gas tank. The proper 2 cycle oil can be had at any home improvement store or garden departments in places like Walmart. Do not use automotive oil or you will have a huge amount of smoke when you run the blower. You can get an owners manual by going on Homelite's website too.
Nov 15, 2015 | Homelite Garden
Model hpw2201. How do I fix an oil leak?
Don't know this model intimately but it looks similar to the Karcher which is really total **** nowadays as its all made of plastic. The motor has a weird switch mechanism but if it tries to run and the motor doesn't then 100:1 the motor is seized. Very unlikely it's the actual motor but the pump is a "swash" plate that opens 3 stainless steel thin flat valves. the bearing that the pump shaft goes through is a phospher-bronze plain bush with a seal each side and if this has dried out then you are screwed. Same if you model has steel roller bearings. However, if it does run and build up pressure and it stops because the output pressure is too high then the overload pressure switch is faulty. If it is the Karcher type then again you are stuffed but if it is similar to the Nilfisk then a replacement is available for around £100 GB Pounds - probably cheaper to buy a new one.
Nov 01, 2015 | Homelite Garden
How to stop bar oil from leaking after its turn off
M/T out oil tank b 4 you put saw away
me I save peanut butter jars for this function , as my stil saw sets perfectly on the rim of one to drain oil into
Jun 17, 2014 | Homelite Garden
I have a chain saw homelite and the bar leaks oil in my case what do i do
Drain oil back out of tank B 4 you put away , its also a very good idea if you drain and purge gas tank as well , as either of these fluids left in saw will cause u problems if you leave in inside for long periods(< week) when you restart saw
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
The 330 homelite chain saw bar is not getting oil.
If the pump is a piston type, there must be valves on both sides of the pump to control the flow of oil in one direction. The one in the tank is called is called a 'duck-bill' valve and may be mal-functioning. Can you move the diaphragm by hand to see if it pumps anything? Did you run the engine without the bar and chain attached to make sure the bar oil-ports were not choked up. Oil should ooze out of the engine side port when running. Hope some of this helps!
Apr 10, 2010 | Garden
Homelite ST-145 oil leaking from muffler
you are right it should be 32:1 for most homelites
Jul 19, 2009 | Garden
Have no 2cycle oil, can you use something other than that for a homelite chainsaw?
I would not use any other type of oil in the saw. 2 cycle oil is blended to desolve in gas and still protect your saws engine. You can get it every where for alot less than a new saw. Good Luck
May 17, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
