Question about Medical
Seca ecg machine ct6 1
INOP light keeps flashing immediately I switch on the machine and this indicates error with the lead cable. I have tried the cable on another machine and it worked fine. Pls help!
  • 4 Answers
SOURCE: MALFUNCTIONING LEAD ON ECG MACHINE
U may have problem with thorax electrode.
Posted on Apr 15, 2009
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
mark24354
  • 776 Answers
SOURCE: MY CONTEC ECG MACHINE CMS80
The power supply (That converts wall (mains) AC power to DC ) is not making "clean" dc power. The most likely problem is the large filter capacitors are " leaking" currect or dry. The small AC component (ripple) that is not filtered from the transformed dc can look like a heartbeat so there is some protection circuitry in these devices. It may be something else, but the large can filter capacitors are most likely. I always recommend that medical equipment be repaired by trained, insured factory technicians. Too many problems are likely to occur and you don't want to misdiagnose someone or electrocute someone because you are too cheap to get it repaired professionally. On the other hand, if you are in central Africa and using it for an elephant research project, get your soldering iron and replace the parts. -Mark
Posted on Sep 17, 2011
SOURCE: ECG AT1 not operate power
Problem in Battery, Replace it
Posted on Aug 22, 2012
SOURCE: We have following errors on
we have a burdick e 350 ekg machine i can put the patient info with no problem
but when it comes to doing the ekg i get an error across the screen that says u1 or uI please help thanks
I have leads on patient and machine says leads off. everything is hooked up, why won't it give me a reading?
Any one of the lead is broken. you have to replace the ecg lead.
All the ecg machines have self diagnosing before its acquire the signals from the patient to print signal. while performing this function the machine detects all the signals from all the leads are prompt or not , if any one of the lead is missing it will not go further and will indicate check cable.
Electronics Equipment Repair Center
Oct 02, 2014 | Medical
Electrode lead off light indicator
Hi I have the same problem.. of you have already solved the problem please let me know
Apr 01, 2014 | Schiller Cardiovit At 1 Ecg Machine
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
hi,
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
ok
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
We have following errors on Siemens BURDICK E350 ECG apparatus: ECG machine not write properly on lead V2 Paper jam accurred skipped 2 ECG paper instead of 1 case. Please help how solve the errors on...
Jan 24, 2011 | Medical
When we connect leads to patient no thing out in ecg paper however before conncting this leads there is noise see in screen
hi,
check the patient cable. if there is any break ( inside ) in the lead it will this problem can occur. also check is the patient cable properly inserted in the socket or not.
if any lead is broken the ecg will not print, also show interference in the display.
try to change the patient cable.
ok
Jan 18, 2011 | Zoll AED Plus wECG Package Graphical...
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
GE MAC 50000 printer error
if you are talking about the patient cable.  Then yes it is available from www.medicaldevicedepot.com
Feb 19, 2010 | Ge Medical Systems 3 Lead Ekg / Ecg Cable...
Apr 09, 2009 | Invacare Medical
Printing 3 leads only not 12
Hello medico001, The info on the Schiller web site states an option of 12 lead for model Cardivot AT. If your unit has this option only the automatic selection will deliver the 12 lead print. For futher info select the web site http://www.schilleramerica.com and click on 'Contact Us'. This should direct you to someone local. Good luck.
Oct 24, 2008 | Schiller Cardiovit At 2 Light Ecg Machine
Medical Logo
54 people viewed this question
Top Medical Experts
Electro Med Services...
masud
masud
Are you a Medical Expert? Answer questions, earn points and help others
