Question about Irons
Bosch Sensixx b7 premier power
Hard to push down steam
5 Suggested Answers
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
ercupa190
  • 12223 Answers
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Posted on Aug 01, 2012
ercupa190
  • 12223 Answers
SOURCE: My Bosch sensixx B5 automatic iron fell from the iron board, the handle opened - I tried to put it together but it's stuck to auto (it doesn't give other heat choices) and the steam button doe
download the manual instr. go to www.fitness.manualsonline.com
and proceed according for help.
God bless you
Posted on Sep 25, 2012
  • 7 Answers
SOURCE: Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Posted on Sep 26, 2012
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
My polti 750w mod PRO VT doesn't produce steam
i woundnt see why not alls that needs to be done is replace the power cord to the unit your local electrician store should be able to fix that
Apr 21, 2010 | Irons
No steam
What you need to do is clean out the steam orifice. (The tiny hole the steam comes out) When water is turned to steam it leaves behind mineral deposits, (Iron, Calcium) Especially if you have "hard" water in your area. Here's what you do. Add some CLR, (Calcium,Lime Remover) to the water you put in the iron, let it sit a while, laying flat, then drain the water out. You want to get the nozzle, to, holding the iron upside down, try to immerse the steam nozzle for a couple of seconds in the CLR or drip some directly on it. You can buy this product in most stores. It works well and fast. Dip your showerhead in it too, you'll be suprised at how it improves water flow. It is safe as long as you follow the instructions.
Apr 06, 2010 | Rowenta DG-920 Iron
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
I cannot get the iron to put forth steam when I am ironing. It isn't even a year old.
take down the iron and clean it the spring is dead probaly you can stretcth it to gain a little tension.good luck.
Nov 10, 2006 | Rowenta DX9800 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Irons Logo
29 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
