Question about Watches
Nexxtech watch instructions - Watches
Why the Time stops after am hour when i use the buttons on the side of the watch
Watch Instructions - WatchStation Official Site: Watches
www.watchstation.com/instructions/
Chic, Stylish & Vintage Fashion from WatchStation. Shop Watches, Wallets, Bags, Belts, Sunglasses, Jewelry & More for Men and Women. Incredible looks at ...
Watch Care & Instructions - Fossil
https://www.fossil.com/us/en/...care/watch-instructions.html
Fossil GroupStainless Steel Watches · Vintage Boyfriend Watches ..... Select your language to download a PDF version of our watch instruction manual. If you do not see ...
Timepieces(Watches) - Manuals - CASIO
Jan 01, 2016 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I need the users manual for NEXXTECH G-SPORT watch, CR2025.
I've had good luck using Google for finding owner's manuals.
Sep 01, 2012 | Casio G-Shock Sports Watch
I can't find the manual for my nexxtech stopwatch model 6315021 Is there an online manual?
http://www.extech.com/instruments/resources/manuals/365510_um.pdf
These instructions work for the nexxtech 6315002A
Sep 24, 2011 | Watches
I try to set my nexxtech watch . I can't find the way to set the clock ... could you advice me how ?
Without knowing which model you have, this should help.
Go to the following link and near the bottom of the page, choose Category - Watches, Brand - Nexxtech and then choose the Model watch that you have. It will give you the option to download/view the manual to set the time.
http://www.thesource.ca/estore/exclusive.aspx?language=en-CA&category=Watches&brand=NEXXTECH
Mar 14, 2011 | Watches
I have a Nexxtech Watch that is both digital and hand driven. I have somehow switched the regular time to a 24 hour clock and don't know how to switch it back. The manual says nothing about it. Any help...
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 21, 2010 | Watches
I need instructions to operate a Ladies Rotary Chronograph Dolphin Standard Watch
Rotary do not seem to list instructions for individual watches but do offer general instructions.
To see these go to http://www.rotarywatches.com/en/service/rotary-watch-care#instructions .
\i hope his helps.
Jul 27, 2010 | Bulova Watch
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
Instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
Mar 02, 2008 | Diesel Audio Diesel Watch
Watches Logo
44 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
