Question about Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ
Ice maker how do i turn my ice make on, it is located on the door of may whirlpool refrig/freezer
  • Anonymous Mar 22, 2014
    Cannot remove ice bin from freezer door..
  • 63 Answers
Look for a on off switch on the ice maker it is soimetimes hard to find im looking at 1 right now its on the right side in front of the ice maker good luck
Posted on Aug 29, 2007
Ge profile refrig - watrer dispenser does not deliver water. Ice maker works fine. What is wrong?
Water solenoid at the rear of the fridge has failed, there is two or three solenoids there, locate the one that does water feed to the door (not ice maker) and do a load test or just replace. Also make sure you dont have a filter safety cut-off, check filter cond and it is located perfectly in housing, check lines inside and outside fridge unit for obstructions. Good luck.
Feb 27, 2011 | Continental Freezer Wide...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
No water,light, or ice on the door
The control panel is most likely at fault. They are all controlled by the panel. Very rare for all 3 devices to go faulty seperately
Aug 27, 2009 | Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Whirlpool 4317943 Ice Maker Kit The ice tray overfills with water. Excess water drips into the ice bin & freezes
Probably the dual valve (solenoid) the one that opens when the ice maker calls for water is leaking.It's located in the back of the refrigerator at the bottom behind the cover.To be sure this is the problem turn off the ice maker and after a while if is water the valve is leaking ,if not the problem is with the ice maker.
Aug 23, 2009 | Freezers
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ Logo
98 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Justin Duby
Justin Duby
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
