Question about Kenmore 24032\24036 Top Load Washer
Whirlpool type 111 washing machine
I am about to use 'No More Yellow' product to remove rust stains from sheets. Directions include how much must be used 'per gallon'. I have a whirlpool type 111 model # 2DLSQ7533JQ2. How many gallons of water is used on 'small', 'medium' and 'large' load settings? I just want to add the right amount of product...
  • 142 Answers
SOURCE: Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Posted on Oct 19, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore HE3 seems to use way more than 10.5 gallons
well the water is meter by the unit ,,but i can give you the read outs,,large loads 12 - 14 gallons..medium loads 10 -11 1/2 gallons small loads 9..these are tech estim...it depend on clothing being wash,,,good luck onthejob
Posted on Jan 23, 2009
ginko
  • 19396 Answers
SOURCE: washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
Posted on May 21, 2009
  • 6277 Answers
SOURCE: Would like to know how
Presumably this information is not in the manual?
Your best bet would be the manufacturer's or vendors' sites. That sort of information the ordinary guys and gals on this forum, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web, are not likely to have at hand, I would think ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 29, 2011
rickyrt441
  • 4399 Answers
SOURCE: I have a kenmore top loading washing machine model
Thanks for choosing FixYa and welcome. Your water level switch is what controls the amount of water going into the washer. It may be bad, but check the water inlet valve first. It may be clogged also. It is possible that the water pump has something blocking the path of the water. It will need to be checked as well. If all these check out, it may be your actual switch that controls the selections of water heights. They can go bad as well.
Posted on May 09, 2011
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
What's your problemI have an inglis royal 100 model 1a 86600 The white clothes come out with brown stains on them. It is old but seems to work well. Could it be the front gasket around the drum? I
there either is a rust mark on the tub or under the agitator oil could be leaking out or metal is rotting where the tranny shaft comes up under the agitator but like you said it's old and parts are starting to rust out and decay
Oct 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Which is better for the dryer and why, dryer sheets or fabric softener in the wash?
Liquid in the washer is better since sheets in the dryer are prone to leaving stains (read back of package about stain warning on every box of softener sheets i have ever seen) also the sheets leave a build up on the thermostats and moisture sensor
While the liquid in the washer softens the clothes and has no build up or staining issues such as the sheets
Oct 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I just washed my whites and I have rust stains on them Help me!
if this problem is due to well water,,ocassionally use a product called White-Out,,,very good at removing rust stains and keeping washer clean of them.
Feb 16, 2011 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
When I wash our clothes, rust stains are on the
Sure sounds like it, however, before anything else, I would shut the water off, remove the hoses, and fill 2 buckets once with the cold, then once with the hot to make sure it's not your water supply.
You'll need to fill them, and let them set for a while to see if anything has settled to the bottom. If they check O.K. then
I would call a local appliance parts house that carries Whirlpool parts. With the complete model number ask them if they carry the tub. If yes, then ask how many have they sold in the last 90 days.
If they have been selling them, then yes, your probably a good candidate. I'd call around for prices, it's fairly expensive.
Jun 25, 2010 | Whirlpool WTW5520S Top Load Washer
Yellow stains after machine washing
Sounds like rust stains, coming off the inside of the drum, you will need to find the source of the rust. Maybe a loose screw or something metal stuck inside the drum. Carefully run your hand around the inside of the drum and check for rough jagged edges to identify anything that should not be in there.
Aug 21, 2009 | Washing Machines
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24032\24036 Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
