Question about Refrigerators
Hotpoint fridge. RLA54
Constant gurgling noise and fridge too cold
bobotfel
  • 236 Answers
SOURCE: Hotpoint RLA54 fridge
Under charge of refrigerant is one of the ice build up in the unit, but try the defrosting method and after all ice are gone operate the unit and check vents if air is present. If no is air present inside the unit may be the blower motor inside has a defect. Its either stock up, burned, or worn out bearing
Posted on Mar 04, 2008
SOURCE: HOTPOINT RLA30 FRIDGE
My Hotpoint refridgerator is 10yr . The frezzer side works fine but the refigerator side is not getting cold. Can this problem be fixed?
Posted on Aug 29, 2008
lojacksdad
  • 121 Answers
SOURCE: unit has stopped cooling and freezing also making gurgling noise
it sounds like the frezzer fan stoped and what your hereing is the freon coming in
Posted on Apr 17, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
Jul 06, 2009 | Dometic RM2620 Refrigerator
Unit has stopped cooling and freezing also making gurgling noise
Apr 17, 2009 | Refrigerators
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
New used refrigerator
HI thanks for your question. a fridge takes at least 24 hrs to get cold and cycle give it some time. the gurgling is normal its the freon boiling in the freezer. its normal. thanks the appliance doc. please rate my answer. thanks.
Jun 19, 2008 | GE Monogram ZICS360NRRH C... Bottom...
is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Apr 21, 2008 | Hotpoint RLA30 Compact Refrigerator
Mar 04, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
