Question about Refrigerators
Kitchenaid kscs25ftms02 Ice crusher does not work
BNewberry
  • 93 Answers
SOURCE: ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Posted on May 16, 2008
  • 1214 Answers
SOURCE: my kitchenaid model kscs25ftms02 water dispenser doesnt work
There is a water valve located at the bottom back of the refrigerator that may have failed or is clogged with trash from the water line. Either is a common problem.
If your know how to use an ohmeter and simple tools like a screw and/or nut driver, I can give you additional instructions on how to troubleshoot. Otherwise, I can search for the P/N and you can order one. You will need to install, or find someone to install for you.
It could also be a filter problem if yours has a filter, or a water supply problem (have you checked the valve a the wall to make sure it was open?).
Posted on Jan 14, 2009
Maytag317
  • 1136 Answers
SOURCE: Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
Posted on May 23, 2009
  • 1891 Answers
SOURCE: Had to disassemble ice crusher and lost order of reassembly
go to web sight . www.apdepot.com. put in your brand and model # look at the ice maker bucket assm. this will give you a picture af the proper assembly . pt # 12517801 .. **** .
Posted on Jan 05, 2010
Testimonial: "Great solution, AND NICE OF YOU TO BE SO HELPFUL! Thank you!"
AndreaBl
  • 218 Answers
SOURCE: MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Posted on Jun 11, 2010
Tpx27pr ice crusher not working
CHANGE AUGER MOTOR ITS BEHIND THE ICE BIN
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Jan 17, 2013 | GE Refrigerators
Ice crusher is broken
Here is a link to the parts you need to fix your ice machine.
Jul 30, 2011 | KitchenAid KSCS25FKSS Side by Side...
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Jan 05, 2010 | Refrigerators
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
My kitchen-aid side by side has suddenly decided to dispense crushed ice only, despite being on the "cube" setting. any suggestions ??
Check the back side of frige (from the inside) where the solenoid is, to make sure it is disengauged.....on mine it was stuck down, causing the crusher to work all of the time... hope this helps.
Jul 14, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Vic
May 23, 2009 | Maytag MSD2650H Side by Side Refrigerator
My kitchenaid model kscs25ftms02 water dispenser doesnt work
Jan 14, 2009 | Jenn-Air JCD2295HES Side by Side...
Need to replace direct drive drum on Kitchenaid Superba side by side
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Oct 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
NO ICE AND IS MAKING FUNNY NOISE
I also have the same model as you. My problem with the ice maker has been build-up of ice under the cube pan which holds the crusher and cubes. ( I pulled the pan out and cleaned up the ice, pushed and re-seated the pan against the back of the freezer where it connects into the crusher motor). In a day or 2 it was working fine again. I got this problem because my son was pullying the pan out and emptying all the ice-cubes into his cooler for his bottles of water and soda., He was not pushing the pan back far enough to seat into the motor of the crusher and this left room for the ice to accumulate under the pan and pushing it forward away from the crusher motor which makes a loud noise when the pan is not seated correctly. There is another problem I had because the freezer was opened to often. The door dispenser became warm and the crushed ice accumulated in the dispenser and froze there, so if I opened the door, ice-cubes would fall out of the pan all over the floor. Also check the back of the pan where the crusher connects to the motor, mine was full of frozen moisture turned to ice which kept the crusher from seating properly. If this is not your problem then I would call a repairman as doing it yourself can be expensive because you may buy a part and then find out the old one was ok and it still doesn't work. Ice maker parts are very expensive .If you are positive that you know what is wrong then by all means fix-it. Also check your frozen food if it is frozen solid or soft, you may have a completely different problem than the ice-maker. Hope I helped some.
                                                     Jerry
Sep 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
