Question about Freezers
970 247622 Need to change the 9v battery
Replace the 9V battery in a Frigidaire Upright Freezer Model GLFU1767FW4?
Hello Kerry;
My name is Peter. I am a retired field service refrigeration technician.
You do not have a 9V battery in your unit. It is usually located on the right hand side of the bottom toe plate. There is a small door. This is just a batter backup if you loose cooling or power.
CE means Communication Error. It is like the check engine light on your car. It just tells you that there is something wrong. The 'd' means door seal. There are no sensors or electronics connected to your door seal.
1.) Is your freezer fan running?
2.) Is your lower back condenser fan running?
If they are running the problem is with your main control board. This is located behind your freezer, on the left hand side and mounted on the side wall with several screws. This is a easy part to replace.
PART NUMBER: 216979700 Cost: $134.00
There are only several connectors on the back and a main cable connector.
If you elect to do the work your self, make sure you ground yourself by touching bare metal. Static electricity will knock out a board. Needless to say before the start of work unplug your unit.
If you were to call me when I was a service tech, I would double the part cost plus at least $140.00 labor.
Jan 03, 2015 | Frigidaire Freezers
I need to install a 9v battery in my Kenmore Elite upright freezer and I don't know where the battery compartment is.
Please expalin to me what this battery powers, i have been a appliance repair technician for over 30 years and have NEVER seen a battery used to power any component, i know manufactures come out with new stuff all the time so i would like to know what this battery does
Jul 23, 2011 | Kenmore 20.6 cu. ft. Upright Freezer 24092
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My kenmore frostless 16 upright freezer alarms
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Alarm goes on then turns off
May 12, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Jun 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
How do I change 9volt battery?
The battery compartment is on the left hand side of the freezer. You can open the battery door with a flat head screw driver. It take a 9v battery.
Dec 19, 2008 | Kenmore 5 cu. ft. / 142 liter Chest...
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
Mar 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
47 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
