Question about Kenmore Freezers
I have a Kenmore upright freezer model #2539264211 which made a screeching sound half and hour ago. This is the first time I have heard this noise. The unit was bought in 1997.
HVACRH20
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
SOURCE: flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Posted on Aug 20, 2008
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
Bat1956
  • 585 Answers
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Posted on Jun 28, 2009
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
Loud clanging noise from Kenmore upright freezer
Check the condenser fan (outside at the rear) and check the coil isn't baking hot. Electronics or board wouldn't cause your symptoms. Check the simple things first!
Jul 10, 2012 | Freezers
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
Started making screeching noise, started to spit
ok,,il be blunt,,,throw it away,,its past its best,,to have it fixed would be costly so do yourself a faver and just buy a new unit,,,,then show it off to all your friends,,,like look what iv got,,,eat your hart out!!!
it would be the cheapest way out of this
Jun 24, 2010 | Freezers
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I LOST POWER TO MY KENMORE FREEZER AND NOW MY ALARM IS GOING OFF.
I would leave the door closed unplug it for half an hour. In that half hour go to sears.com customer service, manuals and guides and type in the full model number from the freezer. You should find an owners manual there to print or just browse for an answer. Good Luck.
Jan 09, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 13.7 Frost Free Freezer
You may want to check the compressor area of the unit.There may be something on the coil or fan blade.(Packing foam,paper, etc)
Dec 11, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
55 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
