Question about Bulova Watch
Watch loses time
I have over $1000 worth of beautiful Bulova men's watches that each lose about 5-10 minutes per day. I tried cheaper daily wear watches and got the same result. I think it is me and something in my electromagetic field. What can I try. I love wearing a watch but need to be able to depend on it. Should I try wind ups, self-winding watches? Recommendations of those? Signed a very busy multi-tasking man! Thank you!
3 Suggested Answers
SOURCE: Rolex runs down
Unfortunately, it actually may be true that the watch is functioning properly.
A self-winding watch that keeps running down can be an early symptom of Parkinson's disease.
Read item 4 "Frozen in Time", at this link, for details:
http://www.dls.ym.edu.tw/neuroscience/news41.html
Posted on Feb 23, 2008
  • 183 Answers
SOURCE: Bulova has mechanical day/date display near 3
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Posted on Sep 22, 2009
My watch is losing time it has a new battery
mcdevito75 here, Even a so called new battery could be weak, who knows how long it was in the store before being sold. Try another Battery from another store.
Sep 20, 2010 | Bulova Marine Star Rubber Strap Watch for...
I have a navitimer world which i bought second hand a couple of months ago, but it seems to be losing time, it loses a minute or 2 a day, and every few days i need to reset the time,i wear it all day and...
Without seeing the inside works (movement) of your new (to you) watch and its parts, it's impossible to tell exactly what is going on, but no need to worry, as that's what competent watchmakers are for. Probably just needs a new spring, which wear over time due to many factors, including temperature, shock and corrosion. Basically, when you wind up any mechanical watch (whether automatic or hand-wound, regardless of age), you're tightening the spring which in turn is what powers up the watch (powering up the gears as it returns to its original position--i.e., unwinds, accuracy dependent thus on the spring among other factors). Sounds to me like it just needs a routine service, mechanical watches being no different than are automobiles, which require regular service as well. In the case of a watch, this will entail a cleaning, fresh oil and regulation, with old springs often simply swapped out for a new ones at that time by a watchmaker; routine services are a standard procedure which can be performed by any competent independent watchmaker, and don't cost a lot either. Most watch manufacturers recommend such service be carried out every 5 years or so, and while some can go longer (especially if not worn daily, same as a car when it comes to oil changes/service intervals), it's important to remember to service your mechanical time pieces which, if you do, will provide you with decades of reliable time keeping. All the best.
Sep 05, 2010 | Breitling Navitimer World 715 A24322 Watch
Watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Feb 23, 2010 | Navy Seal Luminox Dive Watch
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
Sep 22, 2009 | Bulova Watch
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
Omega Seamaster gaining about 10 minutes per hour
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
Jun 07, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
All my watches losing time
good day,
hope this link below will solve your problem.
watches
Feb 25, 2009 | Skagen 355LGSC Wrist Watch
Losing TIme and Stopping completely!
i think you may need to change the battery!
Feb 16, 2009 | Kenneth Cole KC1346 Watch for Men
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Bulova Watch Logo
14 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
