Buzzing noise on Murphy LCD TV
I have a Murphy LCD TV, model TV37F10DM, There is a loud buzzing noise from it when then the programme on the screen goes dark or Black
Garfunkel01
  • 56 Answers
SOURCE: Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Posted on Aug 16, 2007
  • 14 Answers
SOURCE: My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Posted on Mar 18, 2011
caroldon
  • 17130 Answers
SOURCE: Polaroid flm-373b lcd tv - making a loud buzzing
Possible that the main power supply unit which is the SMPS- switch mode power supply- has a faulty capacitor or in the INVERTOR board which has changed the value and so the frequency being changed can cause higher huming level- reduced to lower frequency.
so check the board for leaks , if so replace. Also check if the threshold voltages are below level in these circuits. if so the capacitor can be identified. If there is change after the component heats then simulate the circuit board and confirm using a hair dryer.
Posted on Sep 23, 2011
jerryg50
  • 1689 Answers
SOURCE: tv making loud buzzing noise
A common cause are failure of decopling capacitors in the audio section, and or the circuit board power distribution that feeds the audio board. Most of the capacitors are surface mount components. The standard fix is to start by changing the circuit boards that have the defective parts.
If the set is under warranty, call for warranty service. Out of warranty service is expensive for these TV sets.
Jerry G.
Posted on Aug 10, 2012
gopakumarg43
  • 75599 Answers
SOURCE: My LCD tv makes a buzzing noise but won't turn on
Check its back-light inverter board. Replace it.
Posted on Aug 21, 2012
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Tv making loud buzzing noise
Jerry G.
Jun 12, 2012 | LG 32LG30 32 in. LCD HDTV
JVC TV LCD Model LT-42PM30 intermittant buzzing noise
Most likely suspect is the power supply board---transformers on that board can and do vibrate hard enough to cause this.
At our shop we either locate the part creating the sound and treat it to hot blue to muffle and remove the noise or if confirmed to be on power board--REPLACE THAT BOARD.
Apr 29, 2012 | Televison & Video
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
A piercing high pitched buzzing noise when on. The sound volumne does not affect the buzzing. Always very loud.
You didn't post a model number but if this is a CRT TV (non-flat screen) the noise may be coming from the high voltage circuit and may be a warning sign of failure in the near future.
Aug 25, 2009 | Samsung Televison & Video
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
