Maytag washer having trouble getting all water out makes a funny sound when it quits
  • Washing Mach... Master
  • 5,668 Answers
Could be motor with pump one unit.
Posted on May 10, 2013
Water stsys in drum
Wow, you have the most problematic washer ever built. This washer was the actual demise of the Maytag Company. What happened was that when Maytag built these washers the drum was at an angle that it retained a large amount of water the drum. This caused problems with odor, bacteria and mold. There was a large class action lawsuit launched against Maytag to the point that they quit producing the washer and ultimately were facing bankruptcy, which they eventually filed for.
In regards to your problem, unfortunately there is no solution. The water residual in the water cannot be removed, the only thing you can do is make sure the door is left open, this may help in evaporating some of the water... another solution is to take a cup of chlorine bleach and poor it in the washer. "DO NOT ADD CLOTHES!" Turn on the washer to a normal wash cycle. When this has completed then make sure that the first wash you do after this a white load in case there is a residual of bleach... if there is mold on the door seal use a bathroom cleanser that will remove mold... DO NOT LEAVE CLOTHES IN WASHER FOR EXTENDED PERIODS OF TIME... THEY WILL SOUR AND YOU WILL NOT BE ABLE TO REMOVE THAT SMELL ONCE IT GETS INTO CLOTHING!
I wish I had better news for you, but my guess is that you purchased this second hand and were not told of this inherent problem.
Apr 19, 2014 | Maytag Neptune MAH5500B Front Load Washer
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
Jun 10, 2009 | Washing Machines
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
