Question about Oasis Hunter 54' Ceiling Fan
Hunter ceiling fan
I had wireless internet connection added to my computer my fans stopped working I have 2 remote controls for my fans neither work I changed the batteries still didn't work the fans are wired separately so one can work without the other the fans can be turned off by switch on the wall but must be turned on by remote hunter fans are about 10 years old never had any problems before now fans are on a 20 feet ceiling so they are hard to reach not sure who to call to fix problem is problem related to digtal wireless Help
  • 2 more comments
  • Anonymous Dec 26, 2007
    I have 2 remote hunter fans , and 1 year after installtion they stopped working . alleast when you want them to , they will some times come on unexpectenly . I aslo live about 200 yds away from a radio twr . I think the hz from the tower is effecting the reciver in the fan . I have a reguler pull cord fan fron hunter and i works fine . I think the only solution is to changr the fans , wich sucks because I paid 250$ a pop for them .
  • Anonymous Mar 01, 2008
    Just installed a remote in our new cieling fan. The fan and light will randomly turn on. Suspect it's random interference, but to change the dip switch settings is a pain in the @$$.
  • Anonymous Apr 25, 2008
    fan or lights turn on
  • kanishkudu Oct 01, 2008
    My three remote controlled ceiling fans stopped working all of a sudden, all at the same time. I did not do any thing different and can not pin point the problem. I had these ceiling fans since last six years and so also wireless internet for almost six years. Any easy solution?
    New Friend:
I have had two Hunter fans for nearly 10 years. The remote receivers can fail from time to time (I have replaced one in each fan). However recently I began having inconsistent operation from the remotes (part no. 85095-01). I thought the problem was interference or the batteries. Once I realised new batteries didn't help, I took a chance and took the remotes apart (one very small screw in the battery compartment and 3 more to remove the board from the housing). I cleaned all of the contacts on the board with a q-tip and a light coating of alcohol. I also cleaned the rubber pads on the buttons that touch the board. Once I snapped the remotes back together, they worked almost like new.
Posted on Mar 27, 2013
  • 328 Answers
Have you contacted Hunter? Have you turned off the wireless internet to see if fans work? You may have to try another internet brand or try moving to another part of the house.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 13, 2007
The frguency on the fans can be changed to anothere by reseting thelittle switches located inside the remot and the reciever. Dave at DLDELUE@CFAITH.com
Posted on Jul 16, 2008
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Can I get help with connecting my smart tv to internet as its not working for me thanks a million :)
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
Nov 01, 2013 | Televison & Video
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
What are the dip switch settings on my hunter fan remote currently pin 1,3,4 are plugged in
That is the code that works with your wireless remote controller. The switches should be set the same in the remote in order for the wireless remote to work.
Sep 06, 2010 | Hunter Ceiling Fan Remote Receiver...
My hunter fan is not working. the remote has a new battery however it will not turn the fan on or off and it will not turn the light on or off. the chain on the fan will only work the light. the fan...
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
Aug 13, 2010 | Hunter Ceiling Fan Light Remote Control
My remote no longer works
Hi. If the software is saying that the update may not be intended for your remote, then all you need to do is a connectivity check. To do this:
1. Click on the "Remote Settings" tab.
2. Click "Manage Remotes."
3. Connect the remote to your computer.
4. Click "Replace Remote"
5. Update the remote.
Apr 09, 2010 | Logitech Harmony 890 LCD Remote Control
I am having a problem adding a hunter 28550 light to my existing hunter ceiling fan. The fan works fine but I can not get the light to work.
It's possible whoever installed the fan originally, did not connect the black/white striped wire to the electric box. Drop the ceiling canopy and let me know what you find.
Mar 31, 2010 | Hunter Ceiling Fan Control Switch
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I changed from Direct TV to Dish and I want to change my remote
HI. Here are some things that you can try.
Ensure:
1. You are not connected to the internet via a router
2. You are not on a wireless network
3. Any firewalls on your computer are disabled
4. Your USB cable and port are good, and the remote is not connected to a USB hub but right into the compter.
Now, please do the following:
1. Uninstall the software
2. Download it again at http://logitech.com/myharmony
3. Install
4. In your computer's add/remove programs, uninstall the Logitech Desktop Messenger
5. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode"
6. Connect your remote and log in to your account
7. Click "Downloads" at the top and select "Firmware". The firmware on the remote will update.
8. Click "Replace Remote" to conduct a connectivity check.
9. Update the remote.
That should get the remote working. :)
Dec 19, 2009 | Logitech Harmony 890 LCD Remote Control
Oasis Hunter 54' Ceiling Fan Logo
1,105 people viewed this question
Top Oasis Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
