Question about Sharp Televison & Video
E202 display on my tv screen
I have e202 display on my screen an no channels how do I fix this an what's wrong with it
3 Suggested Answers
gopakumarg43
  • 74383 Answers
SOURCE: screen display says channel fixed,
Hello
Your TV has channle fixed at advanced setting options.
To select this option "Press Menu" and "Press Up or Down" button to select "Channel Fix". A Yagi Antenna symbol" will be displayed, when this option is selected.
Select this when you have a cable bod or satellite reciver connected.
2-6: select this to "fix" your TVs channel setting to 2-6 and use the cable box or satellite reciver to change channels. Select one of these settings if you have connected the equipment to the VHF/UHF JACK.
Video-1: Select this if you have connected the equipement to to the AUDIO and VIDEO IN jacks.
Select "Off" to turn off the "Channel Fix" feature.
When you select "channel fix", the favorite channel cannot be used.
When you select "channel fix", you cannot use Channel Skip/Add or autoprogram in the TV setup menu. To use them, select Channel Fix to :Off".
Ok.
Posted on Dec 13, 2010
  • 11800 Answers
SOURCE: Failed to received broadcast E202. what's
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Posted on Oct 07, 2011
Comcast tv failed receive broadcast e202
Check the input cable to the TIVO is is firmly connected at both ends?
Dec 16, 2013 | Tivo Televison & Video
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Failed to received broadcast E202. what's wrong?
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Failed to receive broadcast e202
The 202 error is usually associated with a bad cable card. In your case, you need to check and see if you have one.
Did you run the Autoprogramming required to load and store the Channels?
If you are attempting to Add digital cable to your TV lineup, you must do that.
And one note -- the digital stations on your TV set will not match the lineup on the Cable box. The box was designed to line up the TV stations according to the guide, but it uses proprietary programming software and hardware to do that.
TV's cannot use the software. so you end up with the low to high frequency channels in your lineup, but it's not similar to the cable channel's lineup.
Try finding USA or TNT lickety-split....you won't.
After doing the full autoprogramming, let me know if you get only the Analog Channels from your Cable provider, or if you get NO channels locking in at all. Either one will likely require replacing the Digital tuner module.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 18, 2011 | Sharp Televison & Video
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
