Question about Sharp DV-RW340U DVD Recorder/VCR
Disc error I purchased DVD-R discs which are compatible with my Sharp VCR/DVD recorder combination model but keep getting a "disc error" message when I try to load a blank disc. Most recently I tried discs meant for copying from videos and they don't work either. I have used Verbatim DVD-R discs in this machine previously and they worked- now they don't.
  • Anonymous Mar 27, 2014
    I have recorded successfully with 2 discs from a new box but It keeps telling me there is a disc error when I insert another one from the same box
I have this same problem so I called Sharp.  This model is  a little older.  When you buy the disks there is a number with an X after it.  If you buy the - R disk the number has to be 4X or less,  for the -RW it has to 2X or less.  Apparently they can still be bought at Office Depot or online.
Posted on Oct 28, 2007
Keep getting disc error c211 when dubbing from VHS to DVD on Sharp combo
Very interesting. It fails for me with DVD-R 16x discs, fair enough, but also with DVD-RW 2x discs, so what next?
Mar 08, 2013 | Sharp DV-RW340U DVD Recorder/VCR
Hello! I am trying to record movies from my VCR collection to make them on the DVD format. I place the tape in the VCR ...then add a "brand new" DVD into the DVD tray (Sony DVD+R)...I then...
You are probably using a disc format which is not compatible with this model unit. Try using DVD-R instead of DVD+R. That should eliminate your error - and work fine. Give it a try - at this stage it is most likely a set of incorrect DVD formats (you can keep any unrecorded/remaining DVD+R discs for your PC (if it supports them) and use them as data storage).
* Single layer DVD-R 4.7GB/120min/4-16X discs are relatively cheap in a spindle tub (25 or 50 discs) available everywhere. *
The good news is no repair costs at this stage.
Apr 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Error message: Can not record on this disk???
In many devices, DVD-R and/or DVD-RW discs do not work. You must use DVD+R or DVD+RW discs. Good luck!
May 20, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Sharp DV-RW340U DVD Recorder/VCR Logo
502 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
