I have a umc 32-188g tv which switches itself off when switched on, then comes back on with no sound
SOURCE: cant hear my cable channels through my surround sound...
Hello, i just saw your post.. i know this reply is so late, and you might have probably found a solution. But i will still give you some guides to help you figure this out.
(1) First and foremost, make sure your connections are set up properly (exactly as in the manual). most HDTV'S require a DIGITAL OPTICAL CABLE to be connected from TV to receiver. Read the manual on your TV and see the required wires for external audio
(2) go to your TV audio settings. Get to the speaker option, and turn it off ( this assumes your expensive TV is an HDTV). By turning it off, you signify that you want the sound option to come only from the speakers.
Hope it helps
Posted on Jan 02, 2009
SOURCE: tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Posted on May 29, 2009
  • 1039 Answers
SOURCE: Samsung Plasma PS42Q96HD keeps switching itself
Replaced swolen capacitors on power board would be first thing. see long thin boards up side. are any of the ics pitted in the center. If so change that board also(buffer boards)
Posted on Sep 01, 2009
  • 6 Answers
SOURCE: My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Posted on Sep 03, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
Hi, Can any one please shed any light on my problem, When I switch the tv on it says DO NOT POWER OFF and under that SCAN it scans upto 100% then scans again upto 100% and again and again does not stop...
Try a hard reset by unplugging the tv while it is turned on. Then push and hold the power button for a few minutes to drain the electronics and memory of all. Then release button and replug back into outlet and then turn on to see if that has done the trick. If that does not work you can contact tech services for a hidden code to restore unit to factory defaults.
Sep 09, 2017 | Televison & Video
Umc 32" lcd sound just goes off after less than 1hour. if switch off and leave 10 mins then switch on sound comes on again for a short time.
It sounds like a thermal component issue since it happens only after playing for awhile. This type of problem is often an issue with the power supply. A link to a TV board distributor is below.
www.tristatemodule.com
Nov 04, 2013 | Dynex DX-L42-10A 42 in. LCD TV
Sound not working on my UMC 23inch tv
Simple things to check:
Speakers in menu not switched "off"
Sound not muted or low either on the SET or BOX if used.
Internal speakers not switched to External (some sets have this)
If a DVD etc plays with sound set is ok and some setting is wrong.
Apr 18, 2012 | Televison & Video
Tv switched itself off and won't come back on
pls describe the type of tv it is ?
Aug 04, 2011 | Televison & Video
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
Unable to switch my 15" LCD TV Receiver on
some tv sets dont come on when there is no picture signal in put, try and check your cables from the wall, aspecially connectors
Mar 24, 2009 | Televison & Video
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
