Question about Food Mixers
Stentura 8000LX I need to adjust the touch of my keys individually. If a key stroke is too sensitive, not showing on paper showing on the screen, which way do I turn the key, clockwise or counterclockwise?
Why doesn't it start?
Did you fit the brushes back properly, they are keyed on one corner and only go in one way. Check all the wires for continuity with a meter. Check the field windings for continuity as well. Make sure the switch contacts are touching in the on position. You need to track the power then (with your meter) and find out where it stops.
Nov 23, 2015 | KitchenAid Artisan Series 5 qt. Stand...
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
Artisan 5KSM150
Remove the back cover and run it LOOK BUT DON'T TOUCH. Are the copper contacts jumping when the speed pulses? If yes you will need to SLIGHTLY twist the copper contact bar so that only one of the pointed contacts touches at low speed. Your adjustments will be done with the power cable unplugged.
Nov 20, 2013 | KitchenAid Food Mixers
Kitchenaid mixer bowl clearance is barely clearing bowl but the head will not lock. If I adjust till the head can lock, the flat beater will be touching the bowl. Is there something wrong with the...
You need to adjust the head height so that the flat paddle is just clearing the bowl. If the head will not lock in that position then you need to investigate the locking mechanism. If the lever goes right forward as far as the slot in the side will allow then you could have a bent rod inside.
Aug 08, 2013 | Food Mixers
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on...
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 24, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
