Question about Garden
Toro timecutter z5000
Electric pto will not engauge. Direct 12 volts to pto will pull the pto in. The green wire from the pto to the silnoid is good. once placed back on the siloniod pto still will not engauge the pto
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
GM Elec
  • 1000 Answers
SOURCE: craftsman electric pto clutch
Yes, you are correct. The coil in the clutch winding has an intermittent short. Once the coil warms up after being applied for a period of time, the windings touch one another and a short is produced.
The clutch will have to be replaced.
Good luck.
Regards,
Posted on May 12, 2009
  • 376 Answers
SOURCE: Toro mower is blowing 30 amp fuse
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
Posted on May 24, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
I have a toro Timecutter z5000. when I pull the handle to turn right it does not respond. what could be causing the problem,
linkage could be off, brake could be stuck on, belt could be off, hydro pump could be bad. take a pick.
Nov 22, 2016 | Toro Garden
On my Timecutter ss5060 it dies when I pull in the drive arms. What could be my problem?
If this is happening while the PTO is operating then your switch is either disconnected, bad, or the wiring to it is broken.
Mar 24, 2015 | Toro TimeCutter SS5060 - 23HP 50 Zero Turn...
My FR691v-as07-R toro timecutter's battery discharges while running. Replaced the Battery, voltage Reg and Diode, still discharges.
It sounds like a job for a volt/ohm meter.
I am not familiar with the model but the basic principles are fairly consistent.
Either there is something causing the battery to discharge at a greater rate than the generator can recharge it or more likely the generator simply isn't working or isn't working efficiently.
In order to charge a battery the generator must provide a higher voltage than the battery or current will not flow. Assuming a 12 volt system the voltage of a fully charged and healthy battery is 13.2 volts. The generator must provide a higher voltage and typically would be around 14.5 volts for solid-state or electronic systems and 15.5 volts for electro-mechanical systems.
Scale the voltages up or down for 6 volt or 18 volt or 24 volt systems...
Isolate the battery from any battery-supplied accessories and then with the engine running fairly fast check the voltage across the battery. If only the battery voltage is present it indicates a generator problem.
As well as providing a higher-than-battery voltage the generator and all the associated wiring and connectors must be able to provide the current flow. In the case of problems it is best to go back to basics and carry out a visual check of all the wiring and connections and check the continuity and insulation of the generator windings and wiring, rectifier diodes, brush gear if there is any fitted and earth connections if it is an earth return type system. It is a good idea to use a wiring diagram for reference.
If the generator is a permanent magnet type there have been rare occurrences where a generator has become inefficient due to a loss of magnetism. I repeat this is a rare occurrence and the fault probably lies elsewhere and a systematic approach and reference to a wiring diagram will usually isolate the fault.
Jan 14, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Toro clutch removal
PTO clutch removal.
remove the crankshaft bolt and be prepared for the clutch to fall
if it doesn't get a soft faced mallet and tap on it
no, get some pb blaster and let is soak for a day or two
then tap a little harder
if still no you will need an air hammer
Aug 14, 2014 | Toro 110-6892 Timecutter Z5000, Z5020,...
Toro troubleshooting
I have a toro timecutter z5000, after disengaging the drive in order to hand push the mower it doesn't go back into drive mode. what can the problem be?
Jan 02, 2014 | Garden
Toro z5000 bogs to almost stalling out with minimal load
I would purchase a compression tester from auto parts store and check compression.
Oct 19, 2013 | Toro 110-6892 Timecutter Z5000, Z5020,...
Garden Logo
198 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
