Question about Drills
Can I put a 110v plug on a 240v charger and will it still work the same?
SOURCE: 110v - 240v
I have had the power supply checked and it only blowed the fuse in my plug the unit is ok. Thank god we have fuses in our plugs in the UK, I have had a variac to bring 240v down to 120v and the power supply is working on my bench at work, I am going to try and change the taps at lunch and tap in the the centre pin so i can run 240v straight through. I had no idea the power supply was external. Why is this the case?
Posted on Feb 19, 2008
SOURCE: re: makita 18v lithium-ion batteries can
of course
Posted on Oct 04, 2008
  • 306 Answers
SOURCE: Plugged it into 240V now it wont run
there is a little relay on the compressor more then likely that is toast. I would start by pulling it off and replacing that. Get back with me and we could go from there. The relay protects the compressor from overloading. Now do you have a fan beside the compressor?
Posted on Feb 07, 2009
  • 21 Answers
SOURCE: my dewalt radio does not work
sadly , chances are you blow the whole power supply on it. you should check with your local servicenter for an estimate on the repair. the units that are made for USA are 110v
Posted on Sep 25, 2009
  • 60 Answers
SOURCE: want to change my 110v plug on my dewalt radio to
Your radio must be a import from the U.S.A. Your radio will not work on 240v YOU WILL BLOW IT UP!!! You need a step down transformer 240v to 110v to goto your radio, you will have to do a search on Ebay in Power tools. You sould notice the lead on your 110v radio is not like normal flex as its only single insulated for 110 volts.... Don't put a normal plug on or you may have to call the fire brigade!!
Posted on Nov 15, 2009
Will my 240v charger work on 110v
Can't say for certain, but there are specific 110V and 220V versions of DCB101.
None are labelled 90-220VAC as would be normal for universal voltage equipment.
If you operate 110V equipment on 220V then you will most likely damage it with overvoltage.
If you operate 220V equipment on 110V then you will most likely damage it in over current or have it simply not work.
It is possible that the charger is universal, just not labelled as such.
Send DeWalt an email.
Mar 29, 2015 | Dewalt 12v Max - 20v Max Li-ion Battery...
Oral-B 12V charger?
I am looking for exact the same as this. Braun should make a 12-volt charger to their tooth brushes. It shouldnt be too complicated and very well possible as the battery in the handle is only below 6 volts.....!
Feb 17, 2012 | Oral B Braun Oral b 3d Excel, Pro Care &...
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
Is it OK for 240v & 110v
Hello bellm.... This shaver operates on a battery. The charger for the battery can be changed to suit the power source available in whatever country you reside. If your shaver was assembled in the states, it most likely has a 110v charger which will work when you plug it into the 110v outlets found in the states. If you buy this shaver in England, for instanice, it will come with a cord and charger that will plug into the 240v system available in the UK. Joe
Thanks for choosing Fixya!
Feb 26, 2011 | Remington R5130
Want to change my 110v plug on my dewalt radio to 240v
Nov 01, 2009 | Dewalt DC011 AM/FM Radio
Dewalt charger
Ok, for easy way, you can just put a 1~2A diode in series of the input 240v power wire, so the after voltage would be around 120v, but for precaution it is better that you put two diode in series, it will give you same result. In addition, I have already tested it on a similar charger, it works fine.
p.s: I do have a similar one that is also 110v, I compared it with other 240v one. They worked same.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
116 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
