Question about Line 6 New Line 6 Pod Xt Podxt Live Multi-effects Guitar Pedal
Reset pod xt live back - Line 6 New Line 6 Pod Xt Podxt Live Multi-effects Guitar Pedal
Podhd400 not working
Try doing a reset as explained in this video-
http://line6.com/support/page/kb/_/pod/pod-hd300400/video-tutorial-pod-hd300-400-factory-reset-r214
May 09, 2014 | Line 6 POD HD400 Pedal Multi-FX Guitar
There is no factory recall on my pod xt pro
That's correct, there is no onboard recall. In order to reset, follow the instructions in this link-
http://line6.com/support/page/kb/_/pod/pod-20-podxt-family-pocket-pod-floorpods/pod-xt-series-factory-reset-reflash-and-firm-r491
Apr 06, 2014 | Line 6 New Line 6 Pod Xt Podxt Live...
How come mmt tweak knob and select knob arent working on my line 6 pod xt live
It sounds like the pots need replacing if re-soldering didn't work. i would take it to a Line 6 authorized service center.
Line 6
Sep 01, 2017 | Line 6 New Line 6 Pod Xt Podxt Live...
Why does my XT Live suddenly blast the volume and reset the wah pedal? tried factory reset but still does it! Annoying!
I would FIRST suspect that the power into the unit might have an intermittent connection. It would probably reset everything if the power momentarily breaks. Power jacks are NOTORIOUS for this problem.
Aug 15, 2011 | Line 6 New Line 6 Pod Xt Podxt Live...
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
I was updating the flash memory of my Pod HD500 and than I turned it off when was updating proccess and now when I connect my HD500, it turns ON and OFF every 20 seconds. I dont know what to do, I cant use...
You have one chance to save this and that is to attempt to flash it again... Flashing is disastrous if power is killed before the flash is complete. You had better hope that the flash boot is still OK so you can redo it from scratch, else it is likely you will have to take it to a service center where they MAY have equipment to re-burn the flash by a direct connection.
Jan 14, 2011 | Line 6 POD HD500 Amp Modeler and Multi...
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Pocket Pod wont turn on
MOST pedal devices ENABLE the battery when the INPUT audio cable is inserted (there is a switch on the jack it plugs into). This automatically connects the battery when you go to use it... ALSO if you leave the cable plugged in will DRAIN the battery.
May 02, 2010 | Line 6 Pod 20 Fx Box
Line 6 New Line 6 Pod Xt Podxt Live Multi-effects Guitar Pedal Logo
23 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
