Question about Exercise & Fitness
Leichtung mat cutter - Exercise & Fitness
One or more of your cut images are not positioned entirely on the mat, They will be skipped
Just follow the steps given at this link, and your cutter should begin to cut again. I just tried it and my cutter is back cutting. Cricut Craft Room Troubleshooting Cricut Help Center
Aug 01, 2016 | Provo Craft Cricut Mini Electronic Cutting...
My sizzix eclips won't turn on
Sizzix Eclips help please - Make The Cut! Forum
forum.make-the-cut.com/discussion/25227/sizzix-eclips-help-please
Jun 10, 2012 - 9 posts - ‎6 authors
I did email Sizzix but they won't answer until during regular business ... If you turnedoff the cutter, then start again, it should work properly. Turning off the grid lines and plus signs on the mat.
Nov 18, 2013
htv question
Sep 16, 2012
Plug In for the Sizzix Eclips, please!
Oct 8, 2011
roland blades
Jun 10, 2011
More results from forum.make-the-cut.com
[PDF]Help - Sure Cuts A Lot
Nov 14, 2015 | Saws
Can you buy hand woven yoga mats?
We provide different types of products made for yoga so that you can relax and meditate. There are lots of products which are related to your health and fitness like- yoga mat, yoga seat and many more.
Visit us at-http://www.theyogshala.com
Sep 10, 2012 | Exercise & Fitness
How do you use a fx-9750GII calculator and inverse matrix to solve the linear system:\r\n w+x+y+z=10 w+2y+z=7 w+x+3y+z=8 w+x+4y+4z=16
One not way would be to define a 4x4 matrix Mat A to hold the coefficients of the linear system. Then define a 4x1 column vector Mat V to hold the constants on the right.
Define a third 4x4 matrix Mat B you may leave filled with 0.
On command line, in Run Mat screen enter (Mat A) ^(-1) and store it in the zero-filled matrix Mat B. this is the inverse of Mat A.
If the inverse of Mat A exists, and it does in this case, the solution of the system is obtained as the column vector, resulting from the multiplication of Mat B by column vector Mat V
You can even shorten the procedure by just calculating ((Mat A)^-1)X (Mat V) [EXE]
To summarize
  1. Create 4x4 Mat A and type in the coefficients of the linear system.
  2. Create a 4x1 column vector Mat V for the right-hand sides
  3. Obtain you solution vector as ((Mat A)^-1)X (Mat V) [EXE]
To get the Mat identifier on command line,
  • use catalog or
  • in RunMat screen, press [OPTN] followed by [F2:Mat], then [F1:Mat].
  • At this point the identifier is on command line, and you have to press [ALPHA] [X,Theta, T] to enter letter A.
  • You use a similar key sequence to enter Mat V
To calculate the inverse of the matrix just use the [SHIFT][)] key sequence which is (X^-1)
Multiplication operator is the regular [times] key.
Nov 16, 2010 | Casio FX-9750GPlus Calculator
Using the cutter on the Baby Lock Evolve
As wide as you want, but anything over a few inches is going to be difficult to guide.
You will get a more even cut if you trim away most of the excess down to a few inches, like with a rotary cutter and mat.
Mar 11, 2010 | Baby Lock Evolve
My zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Mar 26, 2009 | Zebra Z4M Printer
How to make program of finfing the determinant of m*n matrix in C coding
I solve your problem but there is a little mistake that I can't find but maybe you can so here what I wrote:
#include <graphics.h>
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
#include <dos.h>
#include <math.h>
#define n 3
typedef struct
double A[n][n];
int size;
}Matrix;
double det(Matrix mat);
Matrix cut(Matrix mat, int x);
int main(void)
clrscr();
double d;
Matrix mat;
mat.size=n;
mat.A[0][0]=1;
mat.A[0][1]=2;
mat.A[0][2]=3;
mat.A[1][0]=4;
mat.A[1][1]=4;
mat.A[1][2]=6;
mat.A[2][0]=7;
mat.A[2][1]=8;
mat.A[2][2]=9;
d=det(mat);
printf("%d",d);
getch();
return 0;
double d=0;
if(mat.size>2)
for(int i=0;i<mat.size;i++)
d+=pow(-1,i)*mat.A[0][i]*det(cut(mat,i));
else
d=mat.A[0][0]*mat.A[1][1]-mat.A[0][1]*mat.A[1][0];
return d;
Matrix cutmat;
cutmat.size=mat.size-1;
for(int i=0;i<cutmat.size;i++)
for(int j=0;j<cutmat.size;j++)
if(j<x)
cutmat.A[i][j]=mat.A[i+1][j];
else
cutmat.A[i][j]=mat.A[i+1][j+1];
return cutmat;
Rate me if it helped!
And if you find the mistake please tell me where thanks.
Mar 06, 2009 | Intel Computers & Internet
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Exercise & Fitness Logo
277 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
