Www d2pad info
Ican't get my wi-fy to work. itstarts,then says connection disturbance, every time. even connect it to my computor and it still doesn't work.
  • Brad Brown Jan 16, 2016
    Hi CAROL LONGSTRETH, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? make model provider?
  • 45 Answers
SOURCE: wi fy not working the driver is not there need the driver
Fill in the information for your computer and version of windows. Then under refine results click on network. The driver should be called wifi. Below is the link
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=338517&machineind=338521&operatingsystemind=343518&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
Posted on Dec 29, 2008
patemi
  • 366 Answers
SOURCE: My wi fy is not
In The system status indicators the wireless status light in the front of laptop Under touchpad must be lit to confirm WIFI activated.
If not active switch On (FN + F5).
Then You can configure your connection
  • 6 Answers
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Posted on Jan 05, 2009
  • 47 Answers
SOURCE: my problem laptop not working wi fi connection connect phone
ok.
its knows that vista isfull of bags and corraps.
the fing is a computer with vista req a heavy vid card such as 9xxx (dont go on 8800 it is waste of money) and you need 2-4 gb ram for your computer to work perfect and so the best fing you can do try to download windows7 beta it is like windows vista but acts like xp wich is the best so look for a good downloadand goodluck.
Posted on Aug 15, 2009
Khman
  • 180 Answers
SOURCE: my sony vaio e series can't connect to the
Hi
You need to make some tests first,
Try to get LAN cable form other PC at home, and plug it in the sony vaio
You need to enable wireless ( Through wi fi switch, of Fn + F2 )
Please tell us your results
Good Luck
Posted on May 13, 2011
Firmware for D2--713G
Hi Teresa
Instructions for updating the firmware are here:
https://www.d2pad.info/docs/OSFirmwareInstallInstruction_D2-713G.pdf
You should be able to download firmware from the D2 site here:
http://www.d2pad.info/index.php?option=com_content&view=article&id=174&Itemid=210
Happy Holidays, and I hope this helps!
D
Dec 14, 2015 | Tablets & eReaders
Tagital tablet will not connect to Wi-Fy. It finds router but says its blocked pls help
You should enter the correct password for the connection with that router, to get an open connection. Check in the router, it did not change to default, after a power outage.
Feb 06, 2015 | Tablets & eReaders
Www d2pad info
Router brand and model?
May 11, 2013 | Computers & Internet
D2pad info
no comand system error? wont start
Apr 23, 2013 | Cell Phones
Cannot connect smartphone to my computer via wi-fy
The smart phone should work fine on any wireless router. Try going to wireless settings on the phone and if it has your network remember click and hold on your network and select forget network. This should clear out any thing cached about your network. Once that is done try re-connecting to your network and enter any password you may have.
Dec 03, 2012 | Computers & Internet
How do i connect to the wifi
If you need to connect your HTC Wildfire to a Wi-Fi network then check out this simple, step-by-step user guide to getting connected wirelessly
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
  1. Access the Wi-Fi settings menu by navigating to the Wireless & networksmenu
  2. Select Wi-Fi settings
  3. Choose a listed network, or add a hidden network by selecting Add Wi-Fi network
  4. If you choose one of the listed networks and it's secured, enter the password, press Connect and you'll be connected to that network
  5. If you wish to access a hidden network, select Add Wi-Fi network and enter the SSID
  6. If a password is required, you'll be prompted to enter this before connecting
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
links that may helphttp://www.htc.com/uk/howto.aspx?id=3381&type=1&p_id=316 http://www.knowyourcell.com/htc/htc-wildfire/wildfire-guides/487458/how_to_set_up_a_wifi_connection_on_the_htc_wildfire.html
Jul 28, 2011 | HTC Wildfire Cell Phone
My wi fy is not working in levano 3000 C200
Dec 29, 2008 | Lenovo 3000 C200 CM 520 1.6G 512MB...
Wi fy not working the driver is not there need the driver
I purchased a KX-TG4323 phone system. I followed the instructions to set up a ringer ID for our two cell phones. Everytime I try to call it still rings to the default setting. I tried several times and it...
Panasonic KX-TG4323 5.8GHZ intermitten Link problem and lose phone connection. Is there a work around or interference causing problem, such as Wi Fy, Fios, neighbor etc. Pleas help
Aug 31, 2008 | Panasonic Lands Phones
Computers & Internet Logo
630 people viewed this question
David Payne
David Payne
