Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel "clog Problem"
We have a Fisher & Paykel GWL11 top load washer. When it gets to the rinse cycle it stops, and begins to beep. When we did the digonostic check it said the pump is clogged, which doesn't seem to be, since water is pumping. We really need help.
  • Anonymous Mar 18, 2014
    Using fabric softener in Fisher & Paykel top load washer
  • Anonymous Mar 30, 2014
    washer smells and stops rinse cycle
    Novelist:
    Champion:
  • 244 Answers
The water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
Major lint clog in the pump at the bottom of the machine.
If the tub is full you will have to siphon or some other way drain the water down as low as possible. There will still be a couple of gallon remaining below the floor of the drum. Make sure you have a plastic dishpan or the like handy with this next step.
Unplug the machine and, if need be, remove the drain hose from the drain receptacle in the wall. Slide the machine out toward you away from the wall until you can tip it back about 45 degrees and lean it against the wall.
The recirculating pump is in the front right of the underside of the drum. Slide the drain pan under the location to catch as much remaining water as possible when the pump is removed. Unhook the power wire clip (2 wire connection clip) and the ground wire (green wire clip). There is a white catch release on the outside rim where the pump meets the opening in the housing. This is a "bayonet" mount which is a "twist/release" and "push/twist" method and not a threaded method. Gently lift this catch and turn the pump slowly (may take a little effort) by hand (!!). As the pump starts to turn water will stat draining around it. Try to catch as much as possible in the dishpan. Once you have the pump loose it will turn and release into your hand. Once the water has stopped draining inspect the pump opening for large lint balls or other debris that collected in the pump cavity of the machine and couldn't pass through the drain or recirculate tubing. Once you have the debris removed, reinstall the pump in the reverse order of your removal making sure the rim lock "clicks" to ensure it's full seal and check your wiring connections. Return the machine to it's upright position, plug it back in and reconnect toe drain hose to it's outlet receptacle. Turn on teh machind and set a cycle all the way to the rinse drain portion of the cycle to see if the pump now sounds and runs normally.
This SHOULD take care of your clogged pump problem and you just saved yourself $100+ for a repairman to do this for you.
The lint filtration of this machine is one of its biggest faults but it only seems to be an issue if you are washing new heavy pile towels or bathmats or area rugs that have a lot of loose fibers.
Hope this helps - good luck!!
Posted on May 27, 2012
  • 1 more comment
  • Jaya Sep 01, 2012
    Thank-you SO much. Thanks to your clear and detailed instructions, I was just able to remove a clog which had stopped my relatively new machine from draining. I just had service people out to fix the same problem less than a month ago, and I was so upset when it happened again, because I knew I could not afford to keep paying them to come out and do repairs. It would be cheaper to buy a new machine... but that was very irritating, because THIS machine is only one year old. But now I know that I can fix it myself, as needed, in just a few minutes. What a relief! By the way, if you have a lot of cats, or furry dogs, this is probably NOT a good machine for you. Both clogs that stopped this machine dead in its tracks were made up of cat fur- blobs of cat fur about the size of a cat's toy mousie.
  • Jaya Sep 01, 2012
    Thank-you SO much- because of your clear and detailed instructions, I was able to remove a clog in my washing machine's pump, and get the machine working properly again. Yay! This is the second time in a month I've had this problem. Last time I called out service repair people, but there is no way I could afford to keep doing that every month! Now I know I can repair the problem myself in just a few minutes. What a relief. By the way, if you have a lot of cats, this is probably NOT a good machine for you. Both times the clog in my washer was composed of cat fur (I have 8 cats) and about the size of a small mouse. I've had cats, and been doing laundry, for around 40 years, and this is the first time I've had this clogging problem due to kitty fur, so it is certainly specific to this F&P washing machine. Thanks again, mtnpotter36. You helped turn my day around, from gloomy to good, and I really appreciate it!
  • David C. Coulter
    David C. Coulter Sep 02, 2012
    Just a note - Fisher & Paykel HAS developed a solution to this issue!! They have developed a lint trap device that is inserted into the center of the agitator at the bottom just above the wing nut that fastens the agitator to the drum. It is a "sock" type trap that has a handle on it for easy removal after each load. You will be amazed how much lint, pet hair, fuzz, etc this little guy catches in the course of the cycle. It isn't cheap - I had to replace my agitator after almost 10 years because the lower "arms" had cracked off. The replacement agitator was about $38 and the lint trap was about the same - but for the price of the agitator alone from some other parts supply houses I got BOTH. Hope this helps a little more!!
SOURCE:
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer won't go into rinse cycle. Stops and gives steady beeping tone
http://www.docstoc.com/docs/25379677/Fisher-and-Paykel-Circuit-Diagram-GWL11
www.fisherpaykelparts.net/partmanuals/GWL11US.pdf - United States Above is a circuit, and a service manual, below are two DIY Washer help sites, to help troubleshoot and repair, the service manual has all troubleshooting and repair instructions.
http://www.washerhelp.co.uk/diy-repair-help.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Jun 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water is not draining and rinse light is flashing
top load fish pak washer wont dump or spin.constant beeps. rinse spin light and center wash light on .could dump valve be bad or how could line get clogged for dump
Nov 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
578 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
