Question about Motorola Mobility H730 Bluetooth Headset
My motorola fell in water
My motorola fell in cold water what do i do???????
Cold water does not enter the Whirlpool Duet front loading washer (Model: GHW9150)
There are two solenoids back where the water enters the machine ( probably an ugly blue color). Possibly the Cold water solenoid failed or the wire feeding the solenoid fell off. Google Washing Machine Solenoid and you can see what it looks like. The Water hoses literally attach to it
Dec 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a droid 2 that fell in water it still works but the screen is to dark i have to put under a lamp to see the screen how to fix it to see the screen again.
Hi, what causes the screen to go dark,is because of the water that it fell in. It didn't try properly inside the phone. Water is not friendly with phone, they damage phones so easily.
The water has damaged the tube that makes the light display .
Phone is a little bit complicated, so i would advice you contact a skilled personnel for assistance in replacing the light that was affected by the water.
Thanks for using fixya...
Jan 11, 2011 | Motorola Mobility DROID 2 Cell Phone
My ZN5 fell in water and will not turn on,please help
you must give this mobile to service center of motorola
Jun 11, 2010 | Motorola Mobility MOTOZINE ZN5 Cell Phone
My motorola razr fell in the toilet. yes, i know
You might try removing the battery pack and sim card then placing it in an area of warm air flow. If the mineralization in the water in which you dropped it wasn't too high, it might recover after several days. It's worth a try and the price is right-
Nov 12, 2009 | Motorola Mobility RAZR V3
Liquid damage
Yes there is a way but you hv to pay the charges you may contact nearest Service Centre if *********** board change you have to pay 80% of handset cost.
May 20, 2009 | Motorola Mobility A630
L6 phone
Hi!
My phone also fell into a bucket full of water. I just gave the phone to the service center for repair and it's now absolutely fine.
I would suggest you to do the same. Also, don't try to switch on the phone as it may lead to short circuit in your phone.
Thank You
Oct 04, 2008 | Motorola Mobility L6 Cellular Phone
Motorola RAZR V3m Cellular dipped in water not on
WOW.... this is a hard one. Cell phone fails in a bucket of water... the solution... buy a new cellphone... and sell your bucket of water...
P.S. everything inside the phone burnt to pieces... game over
Dec 03, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3 Cellular Problems With Water Damage
yes it is bad
getting hot means that the internals are frying or shorting out
leave the battery off of it for about a week then try it again.
I really don't like your chances of it working properly again though.
Good Luck
Nov 17, 2007 | Motorola Mobility RAZR V3
Regarding motorola
open the battery cover of your phone and remove it the battery. Underneath you should see a small circular sticker. If it is red your phone has internal water damage. You may need to get the keypad replaced.
Oct 28, 2007 | Motorola Mobility SLVR L7 Cellular Phone
L6 fell into water - sticker still white
leave the battery out of the phone for 24 hours, lay the phone face down in a window seal where it can get dry heat. magic
Oct 09, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility H730 Bluetooth Headset Logo
22 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
