Question about Fisher and Paykel DGIX2 Dryer
Service manual My display lights flicker and sometimes the machine will not start. Help?
Traction active, service ride control, service stability, sometimes brake light on dash comes on with or without abs light. also noticed drop in power (max speed 10mph) also noticed air bag lights in...
not that this is going to really help your overall problem but I can tell you that smelling antifreeze in the cabin and if the foormats are wet in the front then it is probably your heater core that has sprung a leak. Think of your heater core as a mini radiator but inside the vehicle and they are usually tucked up inside the dash somewhere and is usually quite expensive to have repaired because of all the labor involved. I just replaced mine in my 2001 Mercury Grand Marquis and it took me about 10 hours to change out. And i am a mechanic.As for your electrical problems I would personally contact the dealership and as them about recalls or technical bulletins concerning your 2003 GMC Yukon xl denali. Good Luck.
Mar 09, 2014 | GMC Yukon XL Cars & Trucks
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Display flickers or doesn't work
have a tech check your set the problem is in the microchip this chip controls a lot of the dvd features.good luck any other question contact me on the this same website or email me at nicodhem@yahoo.com
May 02, 2007 | Sanyo DRW-500 DVD Recorder
Fisher and Paykel DGIX2 Dryer Logo
91 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
