Question about Fisher and Paykel DGIX2 Dryer
My display lights flicker and sometimes are lit but won't start. Help?
Sometimes the car won't start and the dash lights and the radio lights flicker
Best place to start is the positive lead on the battery . Remove the lead and clean battery pole and terminal using sand paper until you have shiny syrfaces. Replace the lead and tighten the terminal . Check the battery for charge condition as what you describe indicates a flat battery
Feb 10, 2013 | Cars & Trucks
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Help please...my Dell desktop Inspiron 518 won't turn on at all.
First Option:Please Take a New Window .
Secon Option:This Falut is Hard.
Last Option:This Falut is Your Board The Board Is Shatig.
Jul 30, 2012 | Dell Computers & Internet
My car has been running fine. Starts each morning once to drive kids to school. An hour later for me to drive to work. But for the last two mornings won't start back up after working 4 hours. I noticed...
Sounds like the alternator is going out the slow way.
Youre kinda lucky because almoat all alternators go out without warning.
Most Autozone shops or places like it will run a test for free.
Good luck,Gary
Sep 23, 2011 | 1992 Honda Accord
1997 chevy cavalier 2.2 engine, intermittent starting problem. Replaced plugs, wires, coil packs. Sometimes it will start and run like a champ. Other times you can't get ut to start at all. I've...
When you say it won't start, do you mean it cranks but won't fire, or it just won't crank? If it just won't crank, you could be having an issue with the starter relay. The often become intermittent before failure. Many owners do not know there is a starter relay because it was added as a recall item i order to protect the iginition switch from burnout. The starter relay is located in the very front of the engine compartment, just to the left of the battery, on the back side of the radiator crossmember.
Aug 13, 2011 | 1997 Chevrolet Cavalier
It's not a notebook. It's an All-in-One. There are flickering horizontal lines on the display, sometimes better, sometimes worse. We checked for, but did not find any new interference source and...
Possibly there might be a problem with the Video Card in the All in One PC.
You can try updating the BIOS version and the Video Card driver to correct the issue. If this won't fix the problem, contact your computer manufacturer for further help with a possible hardware problem.
Aug 07, 2011 | Sony VAIO FRV37 Notebook
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Hi i got a new samsung nc110. power is on but screen is blank and won't start up
Check the activity lights, to the left of the trackpad, Is the hdd light flickering? If yes, chances are you have a "broken" logic board/motherboard or even just the display adapter is dodgy.
Since it's new, take it back to the shop or contact Samsung directly.
Jun 11, 2011 | Samsung N110-12P Notebook
Fisher and Paykel DGIX2 Dryer Logo
23 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
