Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
The clutch was changed once but didnt last very long. i want to change it this time but having a hard time finding which one i need
  • Bernie May 11, 2013
    the clutch is raddling loud and there are 3 different clutches for this mower but i dont know which one i need
    New Friend:
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
Posted on Aug 26, 2013
  • Paul Aug 26, 2013
    Paul
3 Suggested Answers
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
How do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Aug 05, 2012 | Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I want to change the transmission belt on a Cub Cadet LT 1045. Everything looks pretty straight forward except the engine pulley. It looks like engine has to be unbolted and lifted high enough to get the...
You can carefully bend back the guides on frame, push in the clutch pedel and secure it with a piece of rope or a bungee cord. (this allows slack in the belt to remove it.
If you wanted to loosen the motor which is time comsuming, you would need an impact wrench to loosen bolt on pto
Nov 15, 2009 | Garden
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
205 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
