Question about Whirlpool WED8300S Dryer
Timer is working but dryer is not moving - Whirlpool WED8300S Dryer
  • 3 Answers
The drive belt has either come off the tentioner pully or has broken into you will have to take it apart to find out.
Posted on May 10, 2013
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Timer on Maytag dryer will not move.
Sounds like timer motor is bad. Most likely will have to replace timer.
Nov 06, 2017 | Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Dryer works but timer won't move; therefore I have to set my own timer and remember to check the clothes.
There is really no fix to the timer. You will have to replace it. I suggest using www.repairclinic.com . You can buy this item at a cheaper rate than a service call. Always remember to disconnect power prior to changing out parts. Good luck.
Apr 18, 2009 | Kenmore 62602 Electric Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
Stops during cycle
Maybe. Will the unit restart in the same position or do you have to move it? If it will work in the same position and all you're doing is waiting for a bit of cooldown...it could be a defective high limit switch that is resetting. If it will restart only after you move the timer, then change out the timer. This is a bit of a mystery since timers generally don't have 'dead spots'...they are designed differently than that.
Dec 24, 2007 | Kenmore 64902 Electric Dryer
DRYER TIMER NOT MOVING
you need to replace a t-stat. the one with 4 terminals on it. i believe its the adjustable t-stat
Jan 23, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
