Question about Lentek Intelli Vac Robotic Vacuum Rapid Charger Vacuum
Battery Where can I find a battery for Model RV01G-E
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
I need a battery for my cordless vacuum Model No. UV-610 72V DC EURO-PRO X. Please let me know price and how to order.
Do you has any of the following model # listed on the unit?
Shark UV610, UV610BL UV610C
THE ID TAG on the battery should be label as Replaces XBP610
You can order the battery pack via eBay for $28 by linking HERE.
Factory direct will double the cost.
Jan 27, 2011 | Vacuums
Plugged in the charger to my model AV-701B electric broom after not using for a few months. Charging lamp went green as soon as I plugged it in. Unplugged the unit but it will not turn on.
The same happened to me. The battery will no longer take a charge. Oreck store was of no help. Do NOT buy the new model it is poorly designed. you can find other brands in the same category at half the price and much better brands for about the same price.
rudy
Oct 08, 2010 | Oreck ElectrikBroom AV-701B Handheld...
Where can i find a battery for model 4100
Roomba batteries can be found at http://www.totalvac.com/roomba_irobot_battery.html
May 20, 2010 | iRobot Roomba Red 4100 Bagless Robotic...
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
Battery for electrolux pronto stick vac 2 in 1
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
Dec 22, 2008 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Battery needs to be replaced in eletrolux pronto 2 in 1 stick vacum,can i order one
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Sep 02, 2008 | Electrolux Vacuums
Lentek Intelli Vac Robotic Vacuum Rapid Charger Vacuum Logo
Top Lentek Vacuums Experts
JoeVacs
Are you a Lentek Vacuum Expert? Answer questions, earn points and help others
