Question about Straight Talk LG840G Cell Phone
Poor signal NO SIGNAL STRENGTH
If i have a smart tv, do I need a booster for an outdoor antenna, I am planning on a 20-30ft pole, for the antenna
The benefit and functionality of a smart tv is derived as much from a good internet connection as from decent signal strength from the antenna.
The ideal height, type and direction of the antenna depends entirely on the signal strength available where you are and the length and type of downlead cable.
If the signal strength is poor it is generally better to use a high gain wideband aerial designed for fringe reception than to use a lower gain and a booster.
It is worth noting a booster can usefully help increase the strength of a weak but good quality signal but there is little advantage boosting a signal that is both weak and poor quality so it is best to obtain the best signal possible before considering a booster.
A low specification downlead can reduce the signal and gather interference causing a bad signal/noise ratio. Using a booster at the end of such a downlead will boost the interference as well as the signal - the best place for a booster is as close to the aerial as possible and masthead types are produced to avoid those types of problem.
It is best practice to use the highest quality downlead cable - double wrapped air spaced low-loss 75 ohm coaxial cable.
Jul 09, 2018 | Televison & Video
I have a nevdia 42" tv. Won't pick up all the air channels
That is a matter of the signal strength, so there is really no fix but to get a better signal.
Dec 03, 2016 | Televison & Video
How to resolve TV tuning issues?
Check the orientation of the antenna. Try to rotate it, and see whether the signal strength varies. If the signal strength is too weak, digital channels will show many problems. Try a signal booster. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 27, 2014 | Samsung DLP HL-P5663W 56" TV
I keep losing connection to my Wifi Extender
Apple have produced a downloadable app for managing this router.
It also acts like a signal strength meter, and can control various modes on the extender.
Check there is not a scheduler or "Good Night" setting on the extender.
EdiRange
Signal indicator
Amber
Flashing
Poor signal strength:
0 - 39%
So your problem is still poor signal strength, your extender is still not within the wireless range or your router.
See Manual.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/EW-7438RPn_Air/EW-7438RPn%20Air_manual.pdf
Aug 19, 2013 | Edimax Network EW-7438RPN Wireless N 300M...
My mother in law has a 3 mth old panasonic tv with built in freeview that keeps going off saying no signal check ariel. ariel has been checked, any ideas anyone please
access the signal strength in the menus and see how it looks. Too strong a signal can also produce the same problems as a weak signal. If it shows full strength but poor quality then it may be too strong a signal.
Mar 23, 2013 | Televison & Video
I have a poor signal how can i make it better nokia 5230 so i can call on my phone
First of all,put the SIM card into another phone which you can be sure that there are no faults with it and check whether you're getting a good enough signal strength than your nokia 5230 phone.
If you're not,then its not a fault with your nokia 5230.
If your area has a poor signal strength from your current service provider,move into another service provider who has more signal strength within your area if you can.
Sep 11, 2010 | Nokia 5230 Cell Phone
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
Jun 12, 2010 | Televison & Video
Casio atomic watch only has intermittent receive indicator
The receive indicator tells you the strength of the signal when the timing signal was transmitted, (this occurs only during the night).
The strength of the signal dictates how much of the indicator is shown i.e. full strength, full picture, half strength, half picture, no picture, no signal.
Signal strength seems to vary with location (how far you are from the transmitter), so perhaps you are in a poor reception area.
Feb 26, 2010 | Tissot Diver Seastar 1000 T19.1.593.51...
Poor wireless signal strength on my laptop
Hello arnystoller,
Here is a small solution for your issue. Refer to the below web site link and try the steps in it.
This is just a suggestion, this might be helpful to you.
If the issue persists, reinstall the wireless drivers and update the Wireless software.
http://www.microsoft.com/athome/moredone/wirelesstips.mspx
Jun 21, 2008 | Computers & Internet
have a go at changing the wireless channel within your router there may be some interfearence generated by your pc that is affecting its signal strength
Oct 29, 2007 | Computers & Internet
Straight Talk LG840G Cell Phone Logo
75 people viewed this question
Top Straight Talk Cell Phones Experts
Mike
Mike
cwradio73
k24674
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
