Question about DeLonghi EC270 Espresso Espresso Machine
Mold in water tank
Ec270 was put away without cleaning. After 8 months I got it out of the cabinet and found white mold in the water tank and dried milk in the frothier. I was afraid to put bleach in the tank as directed by a friend. I cleaned it but I want to make sure there is no bacteria or harmful residue. Is there hope?
3 Suggested Answers
cpt_cavman
  • 69 Answers
SOURCE: How to remove and clean milk out of espresso water tank :-(
NO the tank is just that a tank and you cant get into it to clean....there are many products for cleaning your coffee pot. Some coffee brewing cleaning products are made by Urnex.Buy mixing a half cup (1/2 cup as i assume espresso meaning a small tank the more vinegar you use the more cycles you'll need to remove) of vinegar with the rest water and brew once or twice 2-3 times or until its right to you.
Posted on May 12, 2009
SOURCE: delonghi milk cleaning solution
Hi - I had the same problem and found your question in a web search. I eventually found the solution I think. On this page http://www.delonghi.com.au/support/material_safety/msds_milk_clean_cofdscale.pdf if you look at page 2 under recommended dosage, it talks about mixing the solution in a 1:10 ratio with water, working the mix onto the nozzle, and then rinsing.
Hope this helps!
Posted on Oct 07, 2010
What cleans mold off of vinyl seats
Removing Mold From Vinyl 1 Mix 1 gallon of warm water with 1 or 2 tablespoons of dish detergent in a bucket.
2 Dip a soft-bristled brush into the bucket and scrub away any mold from the vinyl surface, rinsing the brush in the bucket as needed.
3 Wipe the vinyl surface with a clean, damp cloth to remove any soap residue.
4 Dry the vinyl with a towel. If possible, move the vinyl item to a dry, well-ventilated area to prevent mold growth in the future.
Apr 19, 2017 | Cars & Trucks
Why mold in coffee machine
I would guess you have not used it in a while. The machine holds like 2 cups of water in the flash heating tank. It can mold if left for a long time. I would suggest reading the manual and following the procedure to clean your machine with white vinegar. I would then run multiple cups of coffee but without the coffee/ k-cup in place. Just to flush out any vinegar left in it.
Sep 08, 2014 | Keurig Coffee Makers & Espresso Machines
Mold removal
Bleach and water (50/50 mix) put it in a spray bottle . shake, and spray it down, be generous. wipe it down spray it again. and if you can set it out in the sun and let it dry. bleach and water kills almost all molds. all the molds you and i would run into
May 01, 2014 | Exercise & Fitness
After taking my AC out of storage for the year I just discovered Black Mold growing inside the unit . Is there a way to take off that air flow screen and get in there to clean it out? What would be a...
remove the screen to get to it but follow these precautions.
In order to get mold out of various surfaces, it is important to first obtain proper protective gear. You should check to make sure you have all the necessary protection before you start, such as goggles and a disposable outfit which you can wear during the cleaning.
The first step is to wet the moldy area with water and soap spray. This stops the mold from continuing to spread through the air, which it will do if you do not spray it first. Then, you can use a vacuum to **** away remaining mold spores from the affected area and any surfaces close by which might also be affected by mold spores.
Next, you want to be sure to rinse all areas where you have scrubbed. You can use a wet-dry vac if necessary if too much water has collected. You should then take some bleach and water and apply it to the surface where containing the black mold. Warning: do not mix bleach and ammonia! This can lead to a deadly combination of gases. Make sure you follow the instructions on your cleaning ingredients labels.
You will probably have to leave the solution on the affected area for 6-8 hours or thereabouts. It should be able to dry on its own. You can also use fans, dehumidifiers, and any other type of air circulation device to let the area dry as quickly as possible.
It is important to note, however, that it is very important to let the mold dry; otherwise, it will reproduce. Every mold spore must have a chance to be completely wiped out to prevent it from coming back at any further date. Once the entire contaminated area has been scrubbed away, it should be okay to start using the previously affected room again for any usual purposes.
Ultimately, black mold removal must be done with care and caution. You must ensure that every surface which has been affected is thoroughly cleaned. If it is not, you run the risk of mold returning which can cause serious health problems, as mold is a deadly substance and can create huge issues for any house or building which is affected by it.
Be sure to properly protect yourself when cleaning non-porous materials or any other household surfaces while you remove mold, both to prevent damage from the mold itself and from the chemicals you use to clean it away. This is very important to ensure good safety and preventative measures for mold removal and permanent care and treatment of the moldy spots.
Jun 08, 2011 | Sovereign ARP-900E Air Conditioner
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    My washing mchine has a mildew odour all the time for last month, its a year old WHY? please
    this smell is caused by mold and mildew that has formed on the upper part of the outer drum -- the main cause of this is the suds in the wash tend to rise above the normal water line and never get rinsed away properly. so to get rid of the smell --- run a empty load of hot water ( hot/hot ) and when the cycle starts - add to the water 1/2 cup of white vineger and 1/2 cup of bleach, also add ( using a small container ) some more hot water to the machine to bring the water level up to a higher then normal height,,, let the machine complete the full wash cycle. now if the smell is still kinda there -- repeat the whole cleaning thing one more time,,, this should remove all traces of mold and mildew that has built up and you should notice a huge difference. to keep this from happening again,, try not to use so much detergent in the wash and after you wash your clothes - leave the lid wedged open slightly to let air into the unit so moisture can escape,, this will prevent mold from growing because the machine will dry out fully.
    now at least once a month do this cleaning with the vinegar and bleach and you will never have this problem again.
    c...
    Feb 04, 2011 | Washing Machines
    Cleaning internal humidifier
    Try using vinegar and distilled water.
    If this does not work try using a little bleach and water. Repeat till mildew is gone.
    Rinse thoroughly Again & Again.
    Everyday humidifiers should be cleaned.
    After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
    Mold & mildew will cause you to get very sick.
    If the mildew does not go away replace your unit.
    May 19, 2010 | Humidifiers
    I heard you are suppose to clean the washer once a month to prevent mold,is that true?
    I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
    Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Mold found in washer
    where ever there was moisture run washer for white wash hot/hot with bleach full load or if u have sanitary cycle this should get any mold or algae under drum and entry to pump with front loads its recommended to either wipe excess moisture off seal and or-- leave door open for a few hrs to let seal dry (not advisably with little ones around)--
    9
    Oct 23, 2009 | Kenmore Washing Machines
    MOLD building on inside of dishwasher
    are your dishes comming out dry at the end of the dry cycle and during dry cycle do you see steam comming out of the vent
    Dec 31, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
    DeLonghi EC270 Espresso Espresso Machine Logo
    55 people viewed this question
    Top DeLonghi Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
