Question about Nikon F4s 35mm SLR Camera
Nikon F4 - how to replace the shutter
Have a fully working Nikon F4s... but just destroyed its shutter curtain! Have also an older F4s whose shutter I can use to repair the first camera. How do I remove / install the shutter unit?
    Novelist:
  • Nikon Expert
  • 357 Answers
Try and find a copy of the Jan/Feb 1993 SPT Journal (try Ebay) which covers this repair, or look for a copy of the Nikon repair manual. If you are not good at small item repair and soldering take it to a professional. Also use a anti-static work mat and wrist strap.
Posted on May 14, 2014
poolseman
  • 206 Answers
SOURCE: nikon f4s
F4 has an electronic shutter so check batteries ( see enclosed image ). If your batteries are fresh but still no power ( see if display comes on in view finder ) clean contacts in the battery holder. If still no joy camera should go in.5abb190.jpg
Posted on Nov 22, 2007
SOURCE: Nikon F4s battery holder
Just found this post, so you might already have one, but have you tried eBay? I got one on there for just £8 sterling (around $15 US) and when it arrived it was in almost new condition. The guy even threw in 6 rechargeable cells, which looked new (and I'm still using them) which must have been worth the £8 I paid him, without the MD21!
Good luck.
Posted on Sep 30, 2008
Steve5
  • 423 Answers
SOURCE: chronic sticking shutter on older Nikon
If the shutter doesn't stick on the M90 position, the problem is electronic. If it does, the issue is mechanical. Try the battery check. Hold it for a few seconds. If the LED goes out, the issue is most likely with the batteries. Use really fresh, top quality batteries. Use only silver oxide batteries, not the alkalines that are often substituted.
Posted on Mar 19, 2009
  • 29 Answers
SOURCE: Touched the shutter curtains
Yes it will have an affect on your shooting. The curtains will not operate correclty if they are opening and closing at different speeds and / or not closing or opening completely. Your film will expose at different levels, and you will not get a correctly composed shot. You could try to coax the curtain back into place by GENTLY rubbing it with a Q-tip in the direction it is supposed to go. But those things are fragile and can be fickle. Your best bet is to take it to a shop.
Posted on Jun 20, 2009
  • 102366 Answers
SOURCE: Nikon N55 camera locks up
The F-- indicates that the camera is not communicating with the lens. There are several reasons for this.
The lens is not capable of communicating. If it's an old lens, without the electrical contacts, then you'll have to set the camera to Manual (M) mode in order to use this lens.
If the lens has an aperture ring, set it to the smallest aperture (biggest F/number) and lock it (if it has a lock).
If the lens has no aperture ring, then the contacts may be dirty. Remove lens, clean contacts on back of the lens and in the mount on the body, then reattach lens.
If that doesn't do it, then either the camera and/or the lens may require service.
Posted on Feb 03, 2010
F4 Manuel
You may download the F4 manual at http://cdn-10.nikon-cdn.com/pdf/manuals/archive/F4-F4S.pdf
The correct settings depend on the subject and on what you want the photo to say to the viewer.
Feb 22, 2014 | Nikon 75-240 F4.5-5.6D AF ZOOM-NIKKOR Lens
Nikon F4 - shutter replacement
Hi Miguel,
It would be better to send it to Nikon. For mere mortals swapping shutters may very much mess up the camera beyond repair. If you truly love the F4 have Nikon do the work and at the same time have them do a CLA as well.
Cordially,
May 10, 2013 | Nikon F4s 35mm SLR Camera
Shutter release does not always fire
needs repairing at a qualified shop, miss my F4S its a work horse
Aug 05, 2012 | Nikon F4s 35mm SLR Camera
NIKON F4 STUCK SHUTTER
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Dec 22, 2010 | Nikon F4s 35mm SLR Camera
I can't seem to get the display to light up,when exp meter is turned on.Bottom values do not display bright.Do I have to have film loaded so those values will light up?I have an F4s.
I got a download of the service manual.and discovered a small slide switch,by the manual shutter knob.
I turned it to the right and now the display lights up fully.
Apr 08, 2009 | Nikon F4s 35mm SLR Camera
Black area in photograph
Unless you are using high-end Nikon Speedlights with camera and flash set for Auto FP High-Speed Sync, your top flash sync shutter speed on the D80 is 1/200 second. The black band you are seeing at faster shutter speeds is because the second curtain of the shutter begins to close before the first curtain reaches the fully-open position (which is when the flash fires). The higher the shutter speed, the shorter the gap between first and second curtains. To get full exposure with flash, there must be an instant when the shutter is fully open -- first curtain completed travel, second curtain not started yet.
"As the speed increases the final image should get lighter" applies to ISO speed. Higher shutter speeds mean less light reaching the sensor, but that's not the cause of the black bands.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon f4s
Nov 21, 2007 | Nikon F4s 35mm SLR Camera
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Nov 11, 2005 | Nikon F4s 35mm SLR Camera
Nikon F4s 35mm SLR Camera Logo
96 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
