Question about Coby TVDVD1350 13 in. TV/DVD Combo
Tv Channels When I turn the tv on there are no channels. How do I get tv channels?
  • 54 Answers
Hi, first check your antenna cable. Second, maybe the tuner is defected or memory chip is burnt.
Posted on May 11, 2013
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Seiki tv returns to setup wizard each time turned on
Go to your settings and Lock your TV ... What this does is Locks in your TV settings and channels .... This should Work for you
Mar 31, 2012 | Televison & Video
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How to tune to tv channels
There is a switch [tv-vcr] somewere in the front.When pressed to tv, you can change the channels FROM the vcr.You will need an "air wave" ANTENNA signal because the cable box individual channels cannot be seen when you place the switch to tv.Now if you have a cable box connected properly and turn that tv-vcr switch to vcr the individual CABLE BOX CHANNELS will show through the vcr.
p.s. There is a small switch (someware in the back of the vcr & the back of the cable box,dish box, etc., etc.) ch.3 or ch.4 and the VCR have to be on the same INPUT channel as the box.
Dec 09, 2008 | Televison & Video
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Coby TVDVD1350 13 in. TV/DVD Combo Logo
77 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
