Question about Raymarine ST40 Wind System Rotavecta speed/direction sensor
Manual I need urgently a wiring diagram to fix my ST40 wind instrument...it wont work anymore even with 12 DCV apllied directly. Help Help
    Sergeant:
  • 415 Answers
Go to the Raymarine.com website, they have manuals for their products even ones that have been discontinued.
Posted on Mar 04, 2014
2 Suggested Answers
  • 961 Answers
SOURCE: My ST40 bidata was working
If this is being used with a transom mount transducer, then you want to make sure it's adjusted properly and that the "pitot tube", so to speak, is clear and that the tubing is not kinked, collapsed, or obstructed. I don't believe these come with a wheel to measure the speed so, you will have to first check your tubing and check for clogs and obstructrions. Check the routing and make sure everything is clear. If you have any doubts, start by relacing the tubing, then the transducer, if no sucess.
Posted on Jul 24, 2011
Thermostat has no 12 DCV power. I need a wiring diagram to find where to power comes from.
go to a jayco service center and ask for a schematics diagram as they will be the only place to get it from
Aug 20, 2016 | RVs
How can one test a ST40 wind instrument ?
According to the Raymarine forum, aside from making sure that the spade lug connections are good and clean, there isn't a field test for the ST40. The recommended remedy is for you to send the complete unit to Raymarine for evaluation. Here's the link to that forum.
Sorry I couldn't be the bearer of better news.
-Steve
http://raymarine.ning.com/forum/topics/st-40-wind-troubleshooting
May 11, 2014 | Raymarine St40 Wind Rotavector E22047
The heater fan only works on the 3rd fan setting, and only blows a little air. The A/C only works minimally when set on defrost and the 3rd fan speed setting. I was told I need a new control switch, but...
you need the service and repair manual in which you will find the part number and also how to fix the part with diagram you can get the manual from the given link http://toolsnyou.com/
Dec 11, 2017 | 2000 GMC Safari
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
Where can I get an installation manual for a Simrad SD 12 Wind Instrument set?
gkalan-
I cannot find any records of an SD 12. Simrad bad an "IS 12" wind instrument...this is a discontinued product but an electronic version of the manual is available on their website. Here is a Link to the relevant webpage. This may or may not be what you are looking for. If not, I would suggest contacting Simrad directly - you can find contact information on their website.
I hope this has been helpful to you.
Regards,
DIYpro
Apr 29, 2011 | Sport & Outdoor - Others
Hello, our Raymarine ST40 depth sounder on our trailer sailer has stopped working only shows 0.00 depth on the display screen. However the metres symbol now flashes on/off. I have checked the cable...
now there is a chance that the transducer is bad ,, but I would check the battery voltage and make sure you have a soild 12 volts to the unit. also in my many years of working with and installing these units on boats I have see the needle pins ( where the plug inserts in the back of the display unit ) bend and/or break off completely. look in the plug area of the display unit and make sure all pins are intact. one more place to look for the problem is in the plug itself, take the plug apart and inspect the wire connection and make sure they are all good. if after all the above has been checked then I would assume that it is the transducer itself.
if you have anymore questions with this problem, please feel free to write back and ask,
c...
Jan 30, 2011 | Raymarine St40 Depth Display E22038
My winch won't work anymore...there is a clicking noise and winch wont turn....I check the connection and its good.
Take your voltmeter and verify your voltage at the switch. If it is 11.5 or better, try reversing the motor. Reverse direction requires less ampreage to run and should work fine, then try forward or wind.
Nov 04, 2010 | Electric Superwinch LP8500 Series Utility...
On a 2004 ford f-350 diesel instrument cluster wont work even with a new one and done check on all the fuses and radio stays on what should i do next
you need to find yourself a wiring diagram for your vehicle and check the live an earth connections to the instrument cluster using a suitable test probe or vault meter if you unable to locate a wiring diagram try and find a donor car which you can compare the power supplys with
Jul 11, 2009 | 2004 Ford F350
ST40 Depth and Knot meter
I traced the line from the mast and it was good so finally ordered a new instrument head "$150", It works now, the head was 2 years old {the length of the warranty} not a very long lasting instrument, hope I get more time out of the new one.
Aug 08, 2008 | Raymarine St40 Depth Display E22038
Raymarine ST40 Wind System Rotavecta speed/direction sensor Logo
91 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
