Question about Kenmore 22422 Top Load Washer
Washer not spinning
I know I've seen thi in here before, but I want to know if anyone has any new suggestions...my Kenmore Series 90 is filling and agitating beautifully, but come spin time, it still sounds like it wants to spin, but does not. I've heard things about belts and couplers, but I looked inside the thing and i don't see anything worth fixing. Help anyone?
  • fittobetied Nov 11, 2007
    I have a kenmore top load washer 700 series and it will not go to the rinse cycle. please heap.
There is a coupler between the drive motor and the tub that costs around $4.00 could be broke or worn out. Also the clutch could be not working...tis is in the same location as the coupler(I'm replacing both at the cost of $30.00 minus my labor)the first three numbers of your serial no. denote the manufacturer...make sure you get the correct part.Kenmore is a marketing name only.Sears does not make their own appliances.Hope this helps.
Posted on Oct 10, 2007
    Novelist:
    Champion:
  • 244 Answers
Not too sure on these makes of washer but all washers either have carbon brushes on the motor locatable by having a wire going too them on either side of the motor will only be 2 carbon brushes on the motor or they have a module which is a small circuit board about 4inche in length if this washer has a module find out how much it is first because it is sometimes cheaper to replace your washer m8 thats all the information you need for this certain problem common fault
Posted on Aug 14, 2007
SOURCE:
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
90 series Kenmore washer won't spin
I have had this happen on a Kenmore in the past, and it was the motor coupling. It is a plastic part, and if it cracks your washer will not spin anymore. If you have the repair parts list, or can find it online, you will find the part I am referring to. Good luck.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Washer leaks after installing new lid switch
Glad this was taken care of. I'm just closing out some old tickets here.
May 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 22422 Top Load Washer Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
