Question about Minn Kota Boating
Keep blowing 3 amp fuse - Minn Kota Boating
SOURCE: 3 amp fuse in sat nav power lead keeps blowing
possibly a spike through the ciggarette lighter plug, try putting slightly larger fuse in ( 4 or 5 amp )
temporarily and see if it blows the slightlty larger fuse. if it does it's more likely to be something wrong with the ciggarette lighter socket if it doesn't blow the fuse it's more likely to be the power supply. Ebay for another one perhaps ??
Posted on Apr 13, 2009
SOURCE: Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
Posted on May 27, 2009
  • 127 Answers
SOURCE: Dometic 57915.531 Air Conditioner Blows 3 amp fuse in control box
Steve,
The three amp fuse is installed in the board to protect from shorts or overloads created by disconnecting or reconnecting components when DC power is still connected to the system. If the fuse is blowing, then you more than likely have a short in the 12VDC system between the control unit and the thermostat.
1. Pull the cover off of thermostat and remove the +12 (or +7.5 depending on the model) wire. Access the other end of the wire in the AC compartment. Using an ohmmeter, touch the end of the wire at the AC with one lead and touch the control box with the other (or any ground source). If you get a reading other than OL or Infinity, then that wire is shorted out in the wall somewhere. If not, repeat the steps for the rest of wires except the ground of course. If all of these wires appear to be fine, you may need to take it in for some more extensive troubleshooting.
Hope this helps,
Jeff
Please rate me!!
Posted on Jul 04, 2009
  • 1244 Answers
SOURCE: EFI 15 amp fuse keeps blowing, any suggestions?
you either got a shorted wire to the injectors or a injector stuck! or shorted
Posted on Jan 18, 2010
Grubhead
  • 5309 Answers
SOURCE: my subwoofer keeps blowing the 3 amp fuse on the
There's an overload in either the power supply section or the amp part of the subwoofer. Overloads are mostly caused by a semiconductor that has shorted (acting just like a piece of wire). Transistors are easy to test with a multi-meter in this condition. For when you put the Ohm meter probes on each leg it will act like you are touching the probes to just one leg.
Posted on Feb 19, 2010
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Lowvoltage fuse keeps blowing
the contactor on the condensor if it blows on a call for cool.
Nov 27, 2012 | Gibson Nordyne GR6GD-X24K045C 2 Ton 13...
Bryant 650a furnace keeps blowing 3 amp fuse
If you keep blowing the 3 amp fuse it usually means you have a short somewhere in your low voltage control wiring or maybe within the wiring of your control box. I would ecommend using your ohm meter or continuity tester and start tracing each circuit unit you find where it is grounded at. It usually is in the thermostat wire where a rat or just an exposed piece of wire is touching metal somewhere. Just keep in mind that it could be a very small part of a wire touching the metal. Also check your low voltage wiring and make sure you have everything wired correctly if any of that has changed. At least you have a 3 amp fuse to blow instead of something else more costly to repair! Hope this helps.
Feb 28, 2012 | Heating & Cooling
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
thanks...
Charlie
May 26, 2009 | Jandy AQUALINK RS TELELINK KIT
Apr 13, 2009 | LG GPS
3amp fuse keeps burning out
when a fuse blows, its telling you that theres a fault. this could be a loose or broken wire.
or alternatively, the fuse rating is too low. you could check the wires are tight. and also possibly try fitting a 5 amp fuse. check first that the fuse is rated correctly for the appliance. usually 3-5 or 13 Amps.
Mike @ compurepair.
Nov 17, 2008 | Goodman GMS90703BXA Heater
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
Boating Logo
29 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
