Question about DISH Network DVR 510 DTV Receiver / 100-Hours Video Recorder
Manual MOD # DISHDVR510 DISHPRO Made by Echostar Tech. Corp.
Hisense tv codes for dishremote
0029,0026.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 13, 2014 | DISH Network Televison & Video
5.0 ir / 118575 remote 1 will not work on sat. functions but will on tv functions..Ive changed the Batteries Echostar Technologies Corp
lt911
I have provided instructions on how to readdress the remote to your receiver. If this doesn't work, we may need to replace the remote. I hope this helps.
Readdress remote to receiver, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Aug 29, 2010 | DISH Network IR Remote Control
I want to use my Echostar Tech. IR remote model 103781 to operate my JVC PCX-101 portable stereo, but I have no instructions or code. Can you help? Thanks .... Doug .... dgplcy@yahoo.ca
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/8.0.shtml This is the site that will help you with your issue.
Thanks for using Fix Ya.
Feb 12, 2010 | DISH Network IR Remote Control
How to open dish network remote control made by echostar
You are better off getting a new remote sent to you.
Feb 08, 2010 | DISH Network 301 DTV Receiver
Echostar 311 box codes ?
You can go to Dishnetwork.com and go to the tech portal. There you can select your receiver type and opt for a manual which will display in PDF format. This will allow you to enter peripheral codes as well if you need them as welll. Thanks for using Fix Ya.
Sep 10, 2009 | DISH Network 311 DTV Receiver
Echostar 5.0 remote
https://rweb.echostar.com/departmental_content/TechPortal/content/tech/remotes/5.0.shtml
Dec 26, 2008 | Universal Remote Control Activity Based...
Urc 4220 won't work my dishpro 501 or my dish 3700.........
DishPro 1005 0775
http://www.oneforall-na.com/set_up_remote.php
Nov 23, 2008 | One For All URC4220 Remote Control
Control Remote Codes
Mike,
Code 246 is the correct code for my Maxent plasma for my dish network remote. Remote is 5.3IR and it was made by EchoStar Technologies Corp. Part #142301. If yours is the same, good luck.
jerry
Nov 05, 2008 | Maxent MX-50X1 50 in. Plasma Television
I need the code for an echostar remote ir103602
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Aug 28, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
