Question about Cooktops
Bosch error code u1
Error code u1
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
Jul 30, 2013 | Electrolux E30IC80ISS Cooktop
Error code er26 & er42 for a bosch cooktop
Do this and follow the common sense. God bless you
Lower motorized latch will not lock; Defective or jammed lower oven door or latch switches; Defective latch motor or its wiring. 1. Check P24 connector on the power board.
2. Ensure door latch switches are operating properly.
3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
4. Check P10 connector and check if latch motor wire pinched to the appliance chassis.
5. If F42 persists, replace power board.
Sep 25, 2012 | Bosch Cooktops
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
Cooktops Logo
419 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
