Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Intermittant lamp cycling
I just replaced the 1468798-14 Lamp Driver with a 1468798-16. The TV comes on, and I get a picture for about 30 seconds and then the picture/lamp goes out while the green light blinks. Then the picture/lamp comes back for about 30 seconds. This goes on indefinitely. The lamp driver error warning happens intermittently as well. Bad lamp or something worse?
  • Anonymous Mar 14, 2014
    green light blinks audio goes off no picture then comes back on
  • Anonymous Mar 31, 2014
    Sound goes off after 30 minutes
I think it was both.  I've replaced the lamp driver and the lamp.  TV works great!
Posted on Oct 13, 2007
  • 105 Answers
Could be lamp or lamp driver the only way to tell is to replac on at a time.
My tv comes on runs for 30 sec. then loses sound and picture for 30 sec. and the standby light flashes green for 30 sec. then the picture and sound comes on . then about 30.sec. later it does the whole...
It is symptom of weak lamp that has been reached to an end of its working hours life but not dead/ broke yet.
If lamp has not been replaced in last 2-3 years then please replace lamp in tv to get solve this problem.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 11, 2011 | Sony KDF-E50A10 LCD TV
When I turn the TV on, it has good picture, then 30 seconds the screen goes blank, then 30 seconds later it comes back on. Repeating this continuously. What do I need to do.
Its time to replace Lamp in tv as current lamp is near to an end of its life and causing this problem.
Lamp replacement is easy and user level job, procedure would be mentioned in user manual.
Please buy Sony original lamp for better picture quality.
Let me know if you have additional question.
Thanks.
Apr 12, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Picture and sound go off every 5 minutes then comes back on
I had this problem (every 30 seconds, not 5 minutes) and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. You can order direct from Sony on line service.
Tom
Feb 15, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
No Picture/Sound
can you go to the error menu?
im assuming it's the lamp however the error menu will tell me more
If the standby light blinks five times repeatedly, that's indication of a "Lamp driver error". The probable cause listed is, "lamp driver faulty". Its also possible that the internal antenna used to detect the presence of high voltage has become mis-positioned. The lamp driver provides the high voltage. If no high voltage is detected, it is assumed that the lamp driver is faulty.
Otherwise, it is assumed that the lamp is bad and the LAMP LED lights
the part number for the lamp is XL2000U. Its available for $200 at http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do. Use the Part or Accessory Number to locate the part.
Jan 17, 2008 | Televison & Video
Sony 60' projection model # kdfe60a20
I finally wet out and bought the tv repair manual. Thought the problem had to be more than the bulb because i was losing sound too. Everything in hte repair manual brought me to the bulb or the ballast. I ordered a replacemant bulb. I spent about 150, which included overnight shipping. I replaced the bulb just before Thanksgiving and haven't had any problems as of yet....
Nov 06, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
326 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
