Will a Condenser Microphone work with
2 Suggested Answers
anymhz
  • 500 Answers
SOURCE: connect a mic mixer to a powered mixer
What kind of output does the mini mixer have? If may not have enough to input your Carlsbro PA
Posted on Nov 27, 2011
Palmo T150 wiring diagram
Hi, Ted before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Palmo T150 wiring diagram Google Search
Palmo T150 2009 service manual DOWNLOAD FREE FULLMANUALS COM
Palmo t150 manual
Palmo T150 2011
http://moto.fans/spec/palmo/2009/palmo-t150/index.html
May 18, 2017 | Palmo Motorcycles
Carlsbro cobra 1100 pa
Check your supply voltage.
May 07, 2014 | Audio Players & Recorders
What causes feedback in my PA system?
Feedback happens when the sound coming out of the speakers travels back into the microphone and then is re amplified and sent back through the speakers
Jan 29, 2013 | Audio Players & Recorders
Where can I get a user manual for Carslbro Marlin 8400 DSP power mixer amplifier
Try Googling (Carslbro Marlin)(8400 DSP)(manual) without parens.
Jan 17, 2013 | Audio Players & Recorders
How can I connect a microphone to yamaha rx v692
If your trying to have a PA sytem with these unit, you need to have a
separate mic mixer.
But if your trying to setup a Videoke Sing-along System , just connect
the Mic to the player Mic Input.
But if you need and feel to DIY, there is another option
and only if you can.
Oct 20, 2012 | Yamaha RX-V692 Receiver
Connect a mic mixer to a powered mixer
Nov 16, 2011 | Radio Communications
My school uses Sennheiser Mic's for it's PA system. Is there an adaptor that would let me connect my CD player to the PA sytem's mic jack via the CD player's 3.5 mm headphone outlet?
The CD is STEREO whereas the MIC is monaural.
One could make an adapter that merges the left and right channels before sending on the balanced XLR input. This involves using an audio transformer or direct input box for the balanced line and is not DIY unless you are elctronically skilled.
The best way to do this is to instead plug the output of the CD into the TAPE inputs that are usually available on the mixer.
One uses usually a 3.5mm stereo splitter cable with RCA plugs for most of them.
Sep 10, 2010 | Sennheiser Epack-835 Professional...
I cant make my condenser mic to work with mixcraft only dynamic w
Condenser microphones need phantom power (48V) to operate. Some condenser mics use batteries to work and get around using phantom power from an audio mixer. hope this helps
Feb 28, 2010 | Samson C01U USB Condenser Microphone...
Change the samson airline 77 microphone for a AMT, for sax player
Unfortunately, you don't have enough information to go on to give you a definative answer.
The Sampson Aireline will plug onto ANY xlr type DYNAMIC mic and should work.
The one thing on the AMT Elite I found said it was a "condenser" type element which means it would NOT work with your Sampson setup. Condenser mics require a Phantom power arrangement to charge the element and operate the local FET input amplifier.
If you are trying to mic a violin, the Airline 77 that was for the dynamic mics is a very poor choice as it is low impedance. Most violin pickups use a Piezo pickup which requires VERY high impedance input amplifier.
For my wife's violin we use an Autolycus pickup and an X2 wireless sytem. The pickup comes from New Zeeland and the X2 is CD quality digital wireless link. You have to make your own connector at the violin for the X2 cable was intended for guitars.
Dec 21, 2009 | AMT Datasouth Violin, Viola, & Mandolin...
Love it...awesome for the price worked perfect ...packed it up traveled from nashville hooked it up again and will not work?
double check that you are providing phantom power to it - this is a condenser. make sure there are no transformers between it and the console which might interfere with phantom power reaching the mic. try an alternate cable and or a different channel on the mixer, etc.
Oct 26, 2009 | CAD Microphones e300^2 (e3002)...
52 people viewed this question
 Grubhead
Grubhead
