Question about Lenovo ThinkPad R61e Notebook - Intel Core 2 Duo T7300 2GHz - 15.4" WXGA - 1GB DDR2 SDRAM - 80GB - C... PC Notebook
Eaia data access error 0187 - Lenovo ThinkPad R61e Notebook - Intel Core 2 Duo T7300 2GHz - 15.4" WXGA - 1GB DDR2 SDRAM - 80GB - C... PC Notebook
  • 4 Answers
Your mainboard may be out and need to be replaced
Posted on May 09, 2013
I am getting a message on my coolpad phone saying data error code unable to establish wireless data connection. What does this mean?
you are recieving the error message due to weak data given by your network provider, try to change your location when accessing wireless data connection. go and find the strong signal outside your home.
Dec 06, 2016 | Cell Phones
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
How repar this problem u2 - 23 sharp arm - 451 u
SRAM memory individual data check
sum error (ICU)
Check sum error for every data in the
SRAM memory of the MFPC section
(Communication management table,
sender registration data, etcSRAM trouble
Control circuit runaway due to noises
ICU PWB SRAM access circuit trouble
.)Automatically initialize the data related
to the check sum error by turning OFF/
ON the power.
Since the registered data are deleted,
register the data again.
Use SIM16 to cancel U2 trouble.
Replace the ICU PWB.
Mar 12, 2015 | Sharp Office Equipment & Supplies
Toshiba Satellite l775-14 has an error message and won't turn on
Buy an external caddy/docking station for your hard disk (IDE or SATA), take the drive out and attach it directly to another PC and access it from windows on the other machine to save your data.
Apr 25, 2012 | Toshiba Computers & Internet
Ibm thinkpad type: 2652-BVG Issue: Boots up past the thinkpad logo to the bios setup.Has fan error and 0187 warning.
one of the cooling fans is out or going first look in the fan outlet vent see if its pluged with dirt or animal hair or anything really if it is use a compressor and blow everything out (this should be done on all electronics at least every three months anyway) if clean then fan needs replaced
Dec 12, 2009 | Computers & Internet
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
IBM Thinkpad 2647
This may be a serious problem, and then it may not be. This is going to be a problem with the system board programing. First thing is go into the bios at start up and load set up defaults, or set the bios to default. If this doesn't work, then use another computer to go to IBM's support site and burn a disc with the bios download on it, and run the bios disc in your machine. If these two don't work, then I'm afraid it's serious. It will be a bad CRC2 problem, which is a faulty motherboard component. With a bad CRC1 or CRC2 it is cheaper to replace the motherboard on these models than it is to have it fixed. I hope that one of the first two solves the problem.
Aug 24, 2008 | IBM ThinkPad A21m 2628 Notebook
Lenovo ThinkPad R61e Notebook - Intel Core 2 Duo T7300 2GHz - 15.4" WXGA - 1GB DDR2 SDRAM - 80GB - C... PC Notebook Logo
369 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
