Question about Mitsubishi WD-Y57 57" Projection HDTV
Yellow light Code 32, replaced bulb
Notice on screen "Air Blocked" Tv shut down. restarted worked fine. Two days later same thing but this time would not turn on. Cleaned dust off housing and fans. now yellow flashing light and code 32. removed and replaced lamp to seen if it would reset code nothing.
ctf1800
  • 4402 Answers
SOURCE: Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Posted on Dec 10, 2007
DrGreeley
  • 3 Answers
SOURCE: mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
Posted on Dec 27, 2007
  • 179 Answers
SOURCE: Status Light flashing yellow after replacing the bulb
your air filter cover is loose or not on.
Posted on Dec 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 30, 2009
  • 1030 Answers
SOURCE: tv says air flow problems
ok what you have there is a faulty thernal sensor nitisubishi has issuued a bullitten to serice centers so check with local service center the repair might be covered under warennty
Posted on Jun 18, 2009
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
2007/57 C220CDi Sport rear right light cluster does not work, bulbs and fuses are fine, reset after restarting ignition first time, did not reset this time
I have the similar situation, while driving got a message on dash that rear lights were not working so proceeded to change bulbs, no solution as problem still persists.someone suggested I buy and replace the rear light fittings and plugs which I did at a huge cost and still the same problem. Any suggestions
Jun 18, 2012 | 2007 Mercedes-Benz C-Class
When startin up it would show a message that air flow was blocked replaced the Thermal Sensor, now the timer lite blinks green then the lamp lite blinks yellow and the green light go out. I hav a new lamp...
After the TV has shut down, without pressing reset: press and hold both the Device (Input) and Menu buttons on the front panel until the green light starts flashing. It will flash a two digit code: 3-4, 3-8, 5-7, etc. You may have to let the TV shut down a couple of times (without pressing reset) before it will give the code.
Please post the code to help me determine the section of the TV that has failed and what it will take to repair it. It may be a good idea to repeat the test a few times to make sure the TV is giving the correct code.
Let me know.so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 21, 2011 | Mitsubishi WD-Y65 65" HDTV
My furnace stopped working. It'd start up shut down start up shut down all in the matter of seconds. Then would fire up and work. it did this maybe once every couple days then it stopped all together. ...
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Mar 04, 2011 | Goodman GMS90703BXA Heater
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
POST Replaced Bulb Problem, Error code = 32
This unit will not go into shut down because the lamp timer is not reset. The error you are getting means the lamp you put in is defective or it is not seated proplerly. Make sure the lamp door is on properly because there is a lamp door safety switch that must be depressed properly or the unit will shut down. When the timer needs to be reset you simply get a message on the screen that tells you so, it does not shut down. There are other things that will cause this problems such as the ballast or even problems in the light engine.
Apr 01, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Yellow Tint on Screen
I would guess that the light engine is not aligned right with the chassis. You will probably have to get into the menus and reset the bulb timer setting to get rid of the replace bulb light. A common problem with these sets is a clogged lint screen causing the set to overheat and shut off after a period of time.
Jan 01, 2007 | Zenith D52WLCD 52" Rear Projection...
Mitsubishi WD-Y57 57" Projection HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
